Author Topic: What did you do to your Royal Enfield today?  (Read 1855500 times)
0 Members and 16 Guests are viewing this topic.
hillntx
  • Shriner Bulleteer
  • 2011 G5 Classic, 2004 Sixty-5, 2010 C5 Classic
Reply #2220 on: September 29, 2012, 01:45:28 am
I just looked at mine and wondered if there is an iron barrell bullet out there that does not leak.
It's just trying to mark it's territory...
Reply #2221 on: September 29, 2012, 02:24:28 am
Yes, there are Iron Barrel Bullets out there that don't leak.
Where is yours leaking?
FiRE Comms
  • '11 C5
Reply #2222 on: September 29, 2012, 02:58:54 am
parked and put up the bike, and heading off to another job, not going to be able to ride again until March...
Chris
jartist
Reply #2223 on: September 29, 2012, 06:22:58 am
Dude, that bites! There's always youtube clips to get the Enfield thump fix but it's just not the same.
Reply #2224 on: September 29, 2012, 10:15:55 am
Speaking of the "Enfield thump", how many miles do I need to put on mine before I hear it?  800 so far, and I'm just not gettin' any.  Still idles too high, too.  If ADB's "before" video (D+D Exhaust thread: http://www.youtube.com/watch?v=_wJHHdihXCg&feature=plcp) is a proper indicator, I may have an impostor...
1 Thump
Reply #2225 on: September 30, 2012, 03:04:15 am
The primary leaks. I may have overtightened it. Whats the recommended torque spec for that.
bikerboo
  • 2011 Classic
Reply #2226 on: September 30, 2012, 06:55:13 pm
mounted a rescue mission on mine to recover him from where I had to dump him yesterday after he broke down.Luckily I had my mate with me so at least I got a ride home on a Tiger 90.So its off to the dealer again for "Stan".Hope its just a loose wire and nothing too traumatic.Just when things were going so well.
Adventure before dementia
Reply #2227 on: September 30, 2012, 07:29:54 pm
The primary cover on the iron barrel bikes is held by one nut in the middle.
It is VERY important to not over-tighten that nut, because it might warp the cover and then it will never seal.
Remove the cover, clean the large o-ring that seals the circumference, and remove it for cleaning if necessary. Don't stretch it, or you'll need a new one.
Grease the whole o-ring with axle grease, and maybe put a little in the o-ring grooves too, and that acts as a sealant, believe it or not.
Tighten it up to about 10 foot pounds and see if that holds the oil, maybe 15 foot-pounds if you need to tighten it. That's that should do it.
If that doesn't do it, then you have a warped cover or a bad o-ring, or something like that.
Reply #2228 on: September 30, 2012, 08:18:27 pm
I got  my short problem eliminated, hopefully cured, as I never did find a definitive short. I did find several bare wire bits that could've caused the short. I fixed those and did some wire rerouting so the wires aren't as tight as a G string. I pulled a lot of connectors apart to try to find a short. I checked my alternator output and the R/R condition. They all passed.
I shortened my fuel line so it doesn't ride of top of the side cover. Just a big general once over. I took it for about a half hour ride and didn't have any problems, so now all I have to do is wait for the weather to cool off again and  do another epic ride.
Lady_Enfield
  • Bluce
Reply #2229 on: October 01, 2012, 06:08:25 am
I relented and took her to a real mechanic....sad day.  Never could get the problem ironed out. :'(
I am Multi-FUNctional!
JVS
  • I love chicken
Reply #2230 on: October 01, 2012, 06:43:04 am
Removed the passenger back-rest off the stock seat and this is how it looks -
  • Global Moderator
Reply #2231 on: October 01, 2012, 07:48:53 am
This must be the longest running thread ever on this forum
www.cyclesidecar.com
FiRE Comms
  • '11 C5
Reply #2232 on: October 01, 2012, 07:59:35 am
and a wealth of information
Chris
  • Global Moderator
Reply #2233 on: October 01, 2012, 08:27:57 am
I checked the stats and it is by far the longest running thread
Reply #2234 on: October 02, 2012, 04:28:53 am
You mentioned that you found some bare wires that might have caused your short.
Where were they in case I run out of things to do and want to look to see if mine are also damaged?
