C5 on tour
44 Guests, 3 Users
Mandar_C500, krusty, Tarnand
August 04, 2015, 12:32:23 am
Author Topic: broken clutch cable  (Read 5170 times)
C.C.
  • 1960 Bullet
Re: broken clutch cable
« Reply #15 on: December 23, 2007, 10:43:03 am »
My 2006 sixty 5 came with spare clutch, brake cable, tire tube as indicated in the manual. Had to use the clutch cable at 4000 miles.
2006 Bullet Sixty 5
Member: Royal Enfield Association #11
fredgold52
  • Macomb, IL Flatlands Rule
« Reply #16 on: December 23, 2007, 10:54:32 am »
4000 miles seems more like what should be expected.  DId you occasionally lube your cables?
Leonard
  • I loved this bike!!
« Reply #17 on: December 23, 2007, 02:12:51 pm »
This thread on this subject may be of interest:  http://www.enfieldmotorcycles.com/forum/index.php/topic,268.0.html
2009 Triumph Bonneville T100
http://www.romeoriders.com
SRL790
  • 1954 350
« Reply #18 on: December 23, 2007, 02:21:45 pm »
I carry a spare clutch and throttle cable on all my bikes, including my Suzuki.  I also carry spark plugs and a spare headlight bulb.  (Had a headlight bulb blow one night on a dark country road whilst crossing the railroad tracks which just happen to be on a corner.  Was very interesting for a few moments, but suprisingly, I made it upright.)
Andy Wiltshire
fredgold52
« Reply #19 on: December 23, 2007, 07:03:07 pm »
That is an informative thread, Leonard.  Nice pictures too.  Too bad about the camera.
scoTTy
« Reply #20 on: December 23, 2007, 08:44:40 pm »
well so far all this sounds good ;D
cheaper than when I had to replace my BMW's rear mono-shock :P :o
sewerman
« Reply #21 on: December 24, 2007, 09:17:14 am »
My 04 cable broke with on 1200 miles.  I bought the heavy doty cable out of the catalog but the transmission end was to big to fit in the clutch yoke so I used the supplied spare.  Keeping the cable lubed, the clutch adjusted and not sitting at a light with the clutch pulled in is everything with a Bullet!
mrunderhill1975a
« Reply #22 on: December 25, 2007, 01:55:24 pm »
My '99 broke the clutch cable at approx 3500 miles, I did some back of the envelope calculations and figured the original cable lasted 20,000 shifts.  The replacement Premium cable has lasted 9000 miles thus far which would be 50 or 60 thousand sifts.  I lubed the cable with 20W50 and lubed the cable ends with a light grease.
