Author Topic: How do you turn the rear spring tension nut?  (Read 1063 times)
Justin T
  • 2008 Bullet 350 import
on: June 24, 2024, 11:49:41 am
Hi all
How do you turn the nut with the 5 position tension notches? I want to make it as firm as possible but no idea how to turn the nut at the bottom of the spring. The bike didn't come with a tool for it.
Cheers
Justin
Paul W
Reply #1 on: June 24, 2024, 01:54:50 pm
You need a ‘C’ spanner. Measure the diameter of the ring then search online.
Paul W.
Justin T
Reply #2 on: June 24, 2024, 02:29:14 pm
Thank you
  • There are no truths outside the Gates of Eden
Reply #3 on: June 24, 2024, 02:37:04 pm
Hi all
Cheers
Justin
      Just use an Allen wrench that fits in the hole.
Justin T
Reply #4 on: June 24, 2024, 04:26:27 pm
I ordered a C spanner
AzCal Retred
  • Chennai Wrencher
Reply #5 on: June 24, 2024, 04:41:13 pm
Channellocks or "water pump pliers" and some cushioning cloth?
Justin T
Reply #6 on: July 18, 2024, 03:25:13 pm
So I bought a C spanner but it didn't work. So I just gave it a good heave with a pipe-wrench. I did lift the back wheel off the floor a little but I think the nut would have moved with just the pipe-wrench.
 ;D
Reply #7 on: July 18, 2024, 11:17:43 pm
 ;D
     Me no unnerstand  :)
      Mine turn very easily by sticking an Allen wrench (or anything) of the correct size into the hole (get a bright light & look for it) that's in the casting of the part with the stepped notches & turning it.
stinkwheel
Reply #8 on: July 19, 2024, 12:22:12 am
You can (probably should?) also use the tommy-bar (part 142632) that came with the bike toolkit.
Although I used water pump pliers last time I did it.
Paul W
Reply #9 on: July 19, 2024, 07:55:46 pm
Tommy had gone AWOL from my tool kit, hence me using a ‘C’ spanner.
(For most owners I’d think that adjusting pre-load is a once only job  in any case).
Paul W.
