Author Topic: Gear box oil?  (Read 921 times)
Bullet Mad!
  • Bullet Mad!
  • Bullet Mad!
on: June 23, 2024, 10:25:35 pm
Hi all.can anyone tell me if it's OK to put just gear oil in gear box of 91 500 bullet or will it leak out terribly? If not OK what should be used?
I just acquired the bike so don't know what is in there whether there is grease or not. Is the only way to check by removing outer & inner side cases.?
Thanks.
HD sportster 1200C
Meteor 350
'91 bullet 500E
c1skout
Reply #1 on: June 24, 2024, 12:52:52 am
#00 grease was the original fill, I believe.
AzCal Retred
  • Chennai Wrencher
Reply #2 on: June 24, 2024, 02:29:29 am
There in an oil fluid level check plug on the side of the gearcase and a filler plug on top. Gear oil is the desired lubricant. I run cheapo Sta-Lube 85W140 with zero issues. Thinner oils seem to result in "notchier" action in my experience, YMMV.
Conversion consists of (as per Snidal) filling the gearbox with engine oil to the check plug then running a couple hundred miles, drain & repeat a couple times. The transmission gears churning, plus heat & vibration emulsify the old grease. After a couple treatments refill with gear oil & move on. The only leakage issues I've had were from the clutch pushrod cap. One machine had a cracked cap and another a bad cap gasket. These machines ARE NOT JAPANESE, so a few drips is to be expected. Back in the day they were as oil tight as anyone else. Keeps the dust down, right? Another use for cat litter. I think the amalgam (oil & grease mixture) filled gearbox was to salve the Japanese oriented Euro & US buyers conscience as grease/amalgam leaks slower than oil. By 1990 when imported Bullets became available in Europe & the USA buyers were conditioned to not see any leakage. Not really possible on this 1935-ish design.
The primary side likes ATF, any multigrade 15W50 or 20W50 engine oil works fine. These are low RPM, low BHP sloggers, not Offenhausers. Any modern multigrade engine oil is way better than the 1940 era straight weight oils. I run Walmart sourced 15W50 Mobil1 ($25/5 quart jug) in everything. I don't own any Space Shuttles. The good news about 3 different oils is that you generally know right away who the big offender is... ;D
Raymond
Reply #3 on: June 24, 2024, 08:57:02 am
Good - I read the Electronic ignition thread first and replied to that. Seems my reply fits with the general consensus.
Now, must go and have a play, filing the piston ring end gaps.
In the garage:
2007 Kawasaki W800 SE Polly
1978 Yamaha XS650 Miss November
2003 Royal Enfield Bullet 500 Deluxe
ddavidv
  • Prefers "Your Majesty"
Reply #4 on: June 24, 2024, 12:17:44 pm
Answered in the ignition thread.
2023 Scram 411, 2007 five speed 'Deluxe', 1964 750 Interceptor
Tarnand
  • Andrew
Reply #5 on: June 27, 2024, 04:07:36 am
This video should answer the oil/grease question once and for all.
https://youtu.be/PaD3wfwu9Gs
2005 KS (ex ES) Bullet 500cc
1994 FLSTC
1983 FXRS
SteveThackery
  • Inveterate tinkerer
Reply #6 on: June 27, 2024, 08:52:09 am
Interesting. So it seems the use of grease in the gearbox was a decision by the Indian factory, not a carry-over from the British Royal Enfield.
Meteor 350
Previous:
'14 B5
Yinzer
  • Pittsburgh, Pa.
Reply #7 on: June 27, 2024, 09:39:43 am
Bilgemaster recommended Quicksilver Marine Lubricant SAE 90 GL-4
I've been using that so far.
No problems.
2022 Interceptor MkIII (My bike)
1998 Iron Bullet 500 (Shared bike)
2023 Hunter 350 (Dad's bike)
AzCal Retred
  • Chennai Wrencher
Reply #8 on: June 27, 2024, 04:01:55 pm
Hard to sell bikes to modern fastidious customers if they have icky oil lightly oozing from the cases on the showroom floor. None of my bikes leak, they just exude class... ;D
