Author Topic: Electra kick spring breaks often.  (Read 1804 times)
Gurpreet Singh Dhaliwal
on: December 14, 2023, 01:41:59 pm
Need advice for my 2011 Electra. Kick spring keeps breaking every 3 months or so. What do I do?
Adrian II
Reply #1 on: December 14, 2023, 01:51:19 pm
If this as a 2011 model, you need to post this in the Bullet with the UCE engine section of the forum (this section is for the 500 AVL export Electra-X and any other AVL model Bullets).
If your springs keep breaking at the same place, check there isn't something with a sharp edge pressing against them.
AzCal Retred
  • Chennai Wrencher
Reply #2 on: December 14, 2023, 06:01:47 pm
Use the electric start?
Adrian II
Reply #3 on: December 14, 2023, 09:30:51 pm
If this is an Indian home market 350 I'm not sure if it HAS an electric start. The original versions of the 350 Electra were kick-start only. The Electra-reference was taken from the electronic ignition. Maybe Gupreet can confirm or otherwise.
