Author Topic: CSC RX4 Adventure  (Read 467 times)
AzCal Retred
  • Chennai Wrencher
on: February 04, 2023, 04:45:04 am
Liquid cooled 450cc single "adventure" bike. About 450 pounds dry, +5 gallon fuel tank, efi 6-speed 40HP motor. Roughly $5,500 plus shipping. This couldn't possibly be the "new" LC450 Himalayan, right?  :o
https://www.revzilla.com/common-tread/2020-csc-rx4-first-ride-motorcycle-review
https://adventuremotorcycle.com/bikes/first-ride-2020-csc-rx4-450-review
SPECIFICATIONS
Length: 82.7 Inches
Width: 34.7 inches
Height: 54.7 inches
Weight: 449.7 lbs
Maximum Load: 330.69 lbs
Seat Height: 31.9 inches
Wheelbase: 56.1 inches
Ground Clearance: 8.1 Inches
Front Tire/Wheel: 110/80-19 spoked wheel, tubeless dual sport tire, black aluminum rim
Rear Tire/Wheel: 150/70-17 spoked wheel,tubeless dual sport tire, black aluminum rim
Brake System: Large diameter dual front and single rear disk brakes with ABS
Cooling System: Liquid
Fuel Consumption: 65 MPG
Fuel Tank Capacity: 5.3 Gallons
Starting Mode: Electric Start
Fuel Delivery: EFI
Transmission: 6 Speed
Engine: Zongshen NC450
Displacement: 450.3cc
Bore x Stroke: 94.5mm x 64mm
Compression Ratio: 11.0 to 1
Horsepower: 40.2hp @ 8000 rpm
Torque: 27.3 ft-lb @ 7000 rpm
Top Speed: 97.5 MPH
« Last Edit: February 04, 2023, 05:39:39 am by AzCal Retred »
