Author Topic: C5 Classic...Normal Engine Noise?  (Read 850 times)
Keef Sparrow
Reply #30 on: April 05, 2021, 08:01:06 pm
UCE engines in the 90's?
The AVL designed UCE engine dates from 1995 in 500cc form and from 1997 all 350 and 500 Bullets featured the UCE engine.
Past: CB125-T2, T500, GT500, Speed Triple, 955i Daytona. Now: Royal Enfield Bullet Trials 500
martinw650
Reply #31 on: April 05, 2021, 08:06:35 pm
2008 for the UCE according to Peter Henshaw's Book.
Keef Sparrow
Reply #32 on: April 05, 2021, 08:17:20 pm
I got my information from Wikipedia (which I know is not 100% reliable) where is says the UCE first appeared in the Bullet Machismo in 1995. I think this model was only available in India.
martinw650
Reply #33 on: April 05, 2021, 08:29:44 pm
That's miles out. The UCE first appeared in 2008.
The AVL lean burn engine was still pre-unit, as was the 5 speed.
fressko
Reply #34 on: April 08, 2021, 09:43:48 am
btw
this is the sound of a brand new tribute black:
https://www.youtube.com/watch?v=pN-hD5wR2pI
axman88
  • Vintage Motorcycle Fan
Reply #35 on: April 08, 2021, 07:05:29 pm
btw
Interesting!  Also has a fairly obvious "valve clatter", in my opinion.
I'd like to solicit some guidance in what to look for to quiet valve noise.  My 2012 C5 has gotten fairly noisy in the last year, and I'd like to get it back to where it was.  I'm right at around 7900 miles on the odometer.  The machine was quite a bit quieter when I purchased it at 1700 miles on the odo.  Here's more background:
           Around 3000 miles there was a substantial increase in valve noise, but it was intermittent.
           Shortly after this, the auto decompressor cam failed, the pin stayed up and things got quite noisy.  I rode the bike a few miles in this condition, then put it up waiting for the replacement cam.
           Replaced the auto-decomp. cam and adjusted cam backlash and the engine was quiet again.
           Now, 5000 miles later, considerable valve noise is present, but appears intermittently.  I can start the engine and won't notice tapping sound at all, but it will appear later, or will be present on a subsequent startup.
           The sound seems at a minimum when I reduce throttle and cruise at moderate rpm.  Seems at a maximum with the engine under load or idling.
           Tapping seems to be coming from exhaust tappet, but hard to localize.
I've checked the rockers.  The blocks are secure and play in the rocker bushings is minimal.  With the rocker covers off, there seemed to be sufficient oil flow to the intake rocker, and three times greater flow to the exhaust rocker.
I'll try to make a recording next week when it stops raining.  My next thought was to open up the cam side cover and adjust the cam lash.  Is it possible to check the lifters in place?
Mad4Bullets
  • 2014 Classic 500
Reply #36 on: April 08, 2021, 07:34:29 pm
Before tearing everything apart, I'd recommend investing in a mechanics stethoscope for starters.  They handily block out all noise except that being picked up by the probe. This simple tool can really go a long way in helping you pinpoint the source of the noise within the engine.
Based on the numerous videos I've seen out of India, it could be valve lash, failing hydraulic lifters, the decompressor mechanism once again, poor oil flow or something in the intake or exhaust rocker areas. The hydraulic lifters seem to be a common noise producer and replacing them can be rather involved. The top end and piston must be removed, as will the side cover. Other solutions are a bit more forgiving.  All can be done with time, patience and basic tools. And of course encouragement from the forum.
martinw650
Reply #37 on: April 08, 2021, 08:45:05 pm
Thanks.
Here's an update:
Bike has been stripped at the dealers and the fault is with one or both of the hydraulic lifters. New parts are on order and the bike will be repaired under warranty.
johno
  • 2012 B5 on the original Portland Dorset UK
Reply #38 on: April 08, 2021, 08:51:48 pm
That's good news in a way, make sure they examine the top of the push rods and rocker boxes for hammer damage.
2012 B5 Bullet
 K&N, sport muffler, 18tooth fr sprocket, Avon style fairing, 1958 pattern British army haversacks. Mitas tyres DiD chain. Carberry plate.
