Author Topic: Asbo 41 ridden and discussed.  (Read 88 times)
Bullet Whisperer
on: March 19, 2021, 11:18:43 pm
This machine has a 19t gearbox sprocket, as per the owner's wishes - I would have stuck with 18t, 'S' cams, with inlet retarded by 1 tooth. I am sure it would do better with the air filter removed and a larger main jet [not to mention a larger carb].
 B.W.
 https://youtu.be/EegtP1l2SiY
Bullet Whisperer
Reply #1 on: March 20, 2021, 12:46:52 pm
Unable to edit for some reason, but it also has a compression ratio of 9.2:1, thanks to a shortened barrel and modified piston crown.
 B.W.
