Author Topic: Tappets Adjustment  (Read 259 times)
pmperez2014
on: March 19, 2021, 06:43:28 pm
Hi, Is there a way to tell if the tappet inlet is too tight without disassembling ?
Can you tell this just by looking at the mark on the magneto rotor through the inspection hole? Thanks
zimmemr
Reply #1 on: March 19, 2021, 07:16:12 pm
Sorry but you have to physically measure it. Checking the valve lash entails removing the fuel tank t gain access to the tappet cover, removing the cover etc. Did resealing your air box help?
pmperez2014
Reply #2 on: March 19, 2021, 07:54:30 pm
Ok thanks for your answer.
I still do not solve the air leak because I do not know how to do it.
I do not know how to seal the air box, do I have to disassemble everything or is it enough to remove the side covers and the seat?
zimmemr
Reply #3 on: March 19, 2021, 08:55:12 pm
The air box is supposed to let air in though the snorkle or air inlet, if you think the airbox is leaking on the engine side, you should be able to get a good look at things by removing the air filter access door and peaking around with a flashlight. You shouldn't have to remove more than the seat and left side cover to get that far, and I'm not positive you have to remove the seat.  I think the owners manual details the operation, you can also find the correct parts page on the Hitchcock's web site which might help.  I wouldn't worry about the valves or anything else until you figure out if you have an air leak.
« Last Edit: March 19, 2021, 09:17:14 pm by zimmemr »
Karl Fenn
Reply #4 on: March 30, 2021, 09:18:01 pm
God l remember the old brits when they has inspection mirrors you could check your tappets, now its tank off inspection cover off, all on the job time, mind you if you don't do it that valve could burn out you would have a much bigger problem, head off, new valve, gaskets, a great deal of time and labour.
  • A Simple Twist Of Fate
Reply #5 on: March 31, 2021, 01:45:45 am
          It's obvious you need to get a book that covers motorcycle engines and how they work and maintenance and  then a book that covers the Himalayan engine and the whole bike and do some homework.
           It's not tappet inlet, it's inlet tappet.
'08 Black AVL Classic.ACEhead 9.8:1/manifold/canister. TM32/Open short bottle/hot tube removed. Pertronix Coil. Fed mandates removed. Gr.TCI. Bobber seat. Battery in right side case. Decomp&all doodads removed. '30s Lucas taillight/7" visored headlight. Much blackout & wire/electrical upgrades
dlapierre
Reply #6 on: March 31, 2021, 04:43:08 pm
It's a simple task, setting the tappets. One of the niceties of the Himalayan is its simplicity. Plus, there are lots of u-tube DYI videos to be found for learning how to do these things of you don't want to follow the manual.
Once you've done it the first time, the next time it'l be really easy.
