After all the major surgery my 1998 500 deluxe has had over winter, cylinder head, clutch, and oil pump overhaul, also a change of handlebar controls, I've had a good test ride today. With a bit of trepidation, owing to the misgivings on here regarding fitting a 18 tooth gearbox sprocket.
The area where I live is very hilly, in fact I live at the top of the highest and steepest hill in Torquay! it is also a bit slow going around here, I kept close to home so was within 30 mph speed limits all the time.
In practice, 1st gear is obviously a bit steeper, I can only describe it as less than a third as steep as second used to be, (does that gibberish make sense?), second, and third, are very useful, I did not get into fourth gear at all.
I did a couple of steep hill starts without excessive clutch slipping to get going, on the steepest hill start, I think it might have struggled with a pillion on.
So far so good, I have yet to get on a faster road or the bypass to test top gear.
Riding solo, around town, purposefully going up and down the hilly bits, was, to me, better than before with the 17 tooth sprocket fitted, I did not have to change gear as much, third gear is good for longer without buzzing it. It might be a bit more demanding 2 up or loaded up with the kitchen sink, time will tell, at the moment, I'm happy with it.
