Author Topic: Interceptor clutch drag  (Read 117 times)
ddavidv
  • Bulletologist
on: March 08, 2021, 01:29:19 pm
Got an issue with my '64 that was sitting for years. Running now, but unable to engage gears when running as the clutch is not releasing fully. Cable adjustment does nothing. Took the clutch apart and cleaned it all as it was gummy from the old oil sludge but still no joy.
With the bike shut off, if I engage gear and pull the clutch lever I can see it all move as it should BUT when I kick it over the wheel will turn, even with the tire pushed against the ground/me sitting on the bike.
No bent discs in the assembly.
ETA:  when I first got the engine running I could have sworn I was able to run it through the gears on the center stand and not have any grinding going into gears. I also feel that with the lever pulled the rear wheel would slow as would be expected. I believe this to be a new occurrence but had not touched anything with regard to the primary or transmission in between.
« Last Edit: March 08, 2021, 01:32:04 pm by ddavidv »
2007 five speed 'Deluxe', 2008 Triumph Bonneville, 2012 Triumph Tiger 800
grumbern
Reply #1 on: March 08, 2021, 03:06:01 pm
How's the clutch center's and basket's condition? If these are worn, it can also make the clutch not free up correctly.
ddavidv
  • Bulletologist
Reply #2 on: March 08, 2021, 11:45:17 pm
Fair question. Didn't actually pull those out.
Karl Fenn
Reply #3 on: April 01, 2021, 09:19:44 pm
You should strip it out check and rebuild, l had a triumph that had been standing for years and it dragged l binned everything of the old clutch including pushrod when it was rebuilt ok.
ddavidv
  • Bulletologist
Reply #4 on: April 02, 2021, 01:04:43 pm
To update:  if you follow my "1964 Interceptor" thread a few posts down you will find a video showing it all. I had a broken spacer behind the clutch assembly and also the whole works was gummed up by the old oil far more than I thought. After cleaning and replacing the parts I think it is working as it should. Firing up the bike tomorrow to find out for certain.
