Author Topic: Front brake light don't work  (Read 602 times)
ronald moens
on: January 08, 2021, 04:33:52 pm
Hello, the front brake light (classic 500, 2020) doen't work, the rear break light is working, the connection to the front brake is ok, what to do? :'(
johno
  • 2012 B5 on the original Portland Dorset UK
Reply #1 on: January 08, 2021, 04:47:25 pm
check the switch is making contact or replace the switch.
2012 B5 Bullet
 K&N, sport muffler, 18tooth fr sprocket, Avon style fairing, 1958 pattern British army haversacks. Mitas tyres DiD chain. Carberry plate.
Johnq
Reply #2 on: January 09, 2021, 02:01:05 am
There's a small rubber boot around the switch mechanism,  give it a wiggle in and out a few times they seem to stick at first,
Looks like rain again
500 tribute black
Monster 695
B25 277 special
Ducati st3 992
ren
Reply #3 on: January 09, 2021, 10:40:17 am
I had this on my 2020 Trials. Spray in a very little GT85 or similar PTFE product under the boot then work the lever several times. As mentioned above, it's almost certainly just a sticking switch.
ronald moens
Reply #4 on: January 09, 2021, 11:19:47 am
Yes, this was the cause, it works now, thanks!!
Mark1971
  • Durham, UK, Continental gt 650 2020.
Reply #5 on: January 16, 2021, 08:57:29 am
I guess it's a common issue with the brake light switch. My 2020 classic was suffering with the sticking switch, purchased a new one and its also doing it. Never had an issue on any of my previous bikes, only this one. Its a bit worrying as I like other road users to know when I'm braking. How long should it take to wear in?  The original switch was only 3 months old and had covered about 1100 miles and I reckon I've used the brakes a fair few times in that distance.
Mark from Durham, UK
Continental gt 650, 2020
Classic 500 - military, 2020
Johnq
Reply #6 on: January 16, 2021, 04:25:20 pm
I pulled the boot back and squirted a little ACF50 in the boot and popped it back on, all good so far, I'm guessing they were originally lubed with a gloopy grease that has thickened,
500 tribute black
Monster 695
B25 277 special
Ducati st3 992
johno
Reply #7 on: January 17, 2021, 12:39:22 pm
be careful, ACF50 rots rubber........
2012 B5 Bullet
Keef Sparrow
Reply #8 on: January 17, 2021, 12:44:36 pm
I've always used WD-40 for this sort of thing. It's good for cleaning things - especially anything electrical.
Past: CB125-T2, T500, GT500, Speed Triple, 955i Daytona. Now: Royal Enfield Bullet Trials 500
Haggis
Reply #9 on: January 17, 2021, 12:45:00 pm
ACF-50 over spray will not harm any rubber components
but saturation of "natural rubber" in door gaskets and window seals or harness gaiters of old cars or
motorcycles (40+ years) should be avoided
WD 40 is petroleum based and will damage rubber components.
Off route, recalculate?
Ove
Reply #10 on: January 17, 2021, 11:09:30 pm
Ive seen reports of it drying out rubber, but in my experience I've never had a problem with overspray. There are a couple of types of plastic to avoid using it on, but rubber, seals etc. have been fine for me, but I don't dowse them in the stuff. Also, I'd doubt it does much that's useful for the rubber. A silicone based product helps bring back the flex in old rubber. Something like Gummi-pflege.
« Last Edit: January 17, 2021, 11:16:39 pm by Ove »
Keef Sparrow
Reply #11 on: January 17, 2021, 11:39:53 pm
I've been spraying it all over everything on bikes and cars for 40 years and never had the slightest problem with it. I always wipe it straight off if it gets my tyres but it's never damaged them.
Ove
Reply #12 on: January 19, 2021, 04:12:01 pm
I'm decorating during lockdown. Needed extra wallpaper paste, so wheeled the Enfield out. Thought, I'll just check the brake lights. Nothing from the front! Levered the little rubber boot off, dab of penetrating oil, then 3-in-1 and all is fine.
Is that boot really only held on by the short length of copper wire? Really? Is there a knack to getting it back on?
Cheers!
Guaire
Reply #13 on: January 22, 2021, 03:59:02 pm
I use a specific electronic contact cleaner spray.
  This job is not about lubrication.
Ove
Reply #14 on: January 22, 2021, 05:37:32 pm
On mine, the tiny white pin was staying in when the pressure from the lever was released. After lubricating, it sprang out and was free to move again.
