Thanks for the welcome, many questions to come, anyone feel the need for a rev counter as thinking about fitting a digital one for the running in period, tia John
You don't really
need a tachometer, unless, that is, you just want one, in which case you absolutely must have it! The topic does come up from time to time, so a quick search of the Forum's archive of past postings on the matter should scare up a whole host of good recommendations.
In a pinch, you could just use a grease pencil, tape strips or similar to mark off the revs on the speedo glass or its bezel for various gears using the table found at
https://forum.classicmotorworks.com/index.php?topic=8325.msg95843#msg95843 and a calculator, namely:
Miles per hour at 1000 rpm for each gear:
1st 5.29
2nd 8.04
3rd 10.64
4th 13.36
5th 16.19
Hence 65 mph (65 รท 16.19) is about 4.014 x 1,000 rpm, or roughly 4,000 rpm in 5th, near 5,000 rpm in 4th, and so forth.
Of course, our Enfield speedos are not exactly renowned for scrupulous accuracy, but this might still help you from overtaxing your ride during its break in period.
