The revised 2810 now have 20 clicks of damping adjustment and 10mm of additional travel, for what it's worth.
was going to say......from Hagon....
"I would recommend our 2810 damping adjust shock absorber for this application.
This shock has preload adjustment on a 3 step cam as well as a single circuit 20 click compression and rebound damping adjuster.
This particular range is very popular with the new Royal Enfield 650 interceptor/continental.
We would take into consideration rider weights and requirements at point of order and get the correct spring rate and internal damping to suit.
Could I get a delivery address? This way I can quote accurately. "
