Author Topic: Hagon Dampers  (Read 3208 times)
NVDucati
  • USA 2020 INT
Reply #30 on: January 15, 2021, 07:49:59 pm
The don’t have the rebound adjusters at the top but everything else is the same as far as I can tell
Clarification question:
Are you saying that the Hagons do not have rebound adjustment?
-OR-
Are you saying that they do have rebound adjustment but the knob/screw is located elsewhere?
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT
Blazingatom
Reply #31 on: January 15, 2021, 08:16:59 pm
They have the 3 position preload adjustment but not the 10 position damping on the top attachment point
Ex-REME aircraft technician
Current bike: Conti GT 650
Previous bikes: Aprilia RS50, Cagiva Mito Evo, zx7r, TL1000r featured in PB, zx6r, Fireblade
NVDucati
  • USA 2020 INT
Reply #32 on: January 15, 2021, 08:59:09 pm
Thanks so much for that. It is important info. I'm in a slow roll to deciding on some rear shocks.
   If I stumbled into some windfall of gold coins, I would go for shocks which have independent damping adjustments for both rebound and compression. For me, the rebound adjustability is the more important of the two. That is my minimum spec, adjustable rebound.
Member: AMA
Hoiho
  • Engorged Member
  • NZ - 2020 GT 650
Reply #33 on: January 16, 2021, 03:24:06 am
Done 600km with the +20mm Hagons on the GT, including a 180km with a pillion yesterday.
Very pleased with the shocks so far - less wallowing, more controlled rebound and not as harsh on big compressions (longer travel helps).
The bike tips in a bit quicker and changes direction more easily, which takes a bit of recalibration, but the bike is slow handling in stock form with the big front wheel so it’s a welcome change.
 I’d go as far as suggesting this bike should come standard with 380mm shocks, for anyone over 5’10”. (I’m 179cm and comfortably ball-footed solo or flat-footed with a pillion).
t552
Reply #34 on: January 18, 2021, 04:20:41 pm
Can supply YSS at discount price if in UK. From £160 inc post for eco. Z series £310 and G Top at £485
olhogrider
  • 650 Interceptor and C5
  • VEGAS!
Reply #35 on: January 18, 2021, 09:50:35 pm
Too bad YSS only makes ugly shocks. I bought my full shroud Hagons purely for looks. They look like the shocks on a 1970 Interceptor.
Blazingatom
Reply #36 on: January 18, 2021, 10:23:34 pm
I honestly think they look nicely made
wachuko
  • '21 Continental GT 650
Reply #37 on: January 18, 2021, 10:34:19 pm
So do I...
It just depends on the look you are going for.  So glad we have many choices to select from for our bikes...
Ride safe!
Wachuko
'19 BMW F 850 GS Adventure
‘21 Royal Enfield Continental GT 650
Blazes Boylan
  • Brooklyn
Reply #38 on: January 18, 2021, 10:50:22 pm
"I bought my full shroud Hagons purely for looks. They look like the shocks on a 1970 Interceptor."  --Olhogrider
I've been eyeing the shrouded Hagons for awhile.  Did you buy yours from Hitchcocks?  Did you get the standard 360mm?  Are they superior to the stock in performance?  Sorry if you've posted about them elsewhere but any feedback would be appreciated.
Hoiho
  • Engorged Member
  • NZ - 2020 GT 650
Reply #39 on: January 19, 2021, 08:40:36 pm
The revised 2810 now have 20 clicks of damping adjustment and 10mm of additional travel, for what it's worth.
Jack Straw
  • Prescott, Arizona
Reply #40 on: March 10, 2021, 02:26:30 pm
Being a harmless eccentric I'm trying lighter springing on my Interceptor.  Alan at Hitchocks is getting some softer items for the Hagon dampers.  The softer springs they list at the moment do not fit the Hagons.
My recent change to softer springs in the forks has made the rear feel too firm.
Interceptor 650, Honda VT500 Ascot at present
Norton Commando, Ducati Diana Mk. III, CB 500/570, KLR 650, Ducati 250 Scrambler, CB 350, Honda S 90, YDS-3, SV 650 and a few others in the past.
Karl Fenn
Reply #41 on: March 10, 2021, 05:18:45 pm
Well that is a point they are expensive l am not that flush at the moment to Buy luxury upgrades.
om15
Reply #42 on: March 10, 2021, 05:52:17 pm
Anybody have experience of these IKON shocks? The price is midway between Hagon and YSS, I had planed to buy the Hitchcock Hagons with rebound damper adjustment, but these look quite good, any thoughts?
https://normanhyde.co.uk/royal-enfield/650-interceptor/ikon-rear-suspension-for-royal-enfield-650-interceptor-gt-continental.html
current bikes
RE Himalayan 2019
RE Interceptor 2020.
Previous, Triumph Trident 900, 03 Bonneville, Adventurer 900, 13 Bonneville, Street Twin. Tracer 700. RE 500 Classic, BSA C15, Yamaha XT500
South West England, retired aircraft engineer.
zimmemr
Reply #43 on: March 10, 2021, 07:29:47 pm
I've used them on a couple of Hinckley Bonneville's they were a huge improvement over stock but whether they're better or worse than the Hagon's or YSS I can't say. It's my understanding that IKON's are essentially the old Koni design.
om15
Reply #44 on: March 10, 2021, 08:22:51 pm
Thanks for that.
current bikes
RE Himalayan 2019
