Author Topic: How Embarrassing!  (Read 114 times)
Black fingernail
on: August 01, 2020, 02:13:09 pm
Went to Paignton this morning, (a very British, bucket & spade seaside town, in Devon), for a coffee, in my favourite coffee shop.
No problems at all, she normally starts first time, except, of course, if people are watching!
Today though, she had a hissy fit, I turned her over once, with no ignition to prime, ignition on, BANG, back fire, not a big one, but after that, no start, Bugger!
Checked points,(have they closed up a bit), all good, put a spare plug in, good spark, compression blew my thumb off plug hole, all good.
Scratched my head for a bit, looked at the carb, THERE IT WAS, just off it's rubber mounting! loosened clamp, pushed back on, tightened back up, BOOM, running like a ten bob watch again!
This little escapade lasted @ twenty minutes, in this time, I fielded seven, stupid, fat, smirkey remarks, like, "that's the beauty of a British bike", et al, I think my reply of, "doesn't yours do this from time to time?" seem to make them waddle off and make a nuisance of themselves somewhere else.
The clamp that holds the carb in place, is a bit careworn, and doesn't seem to tighten as much as it should, so, a couple of replacements seem a good idea.
All in all, an eventful morning.
It's metal, it doesn't understand!
Enfield 500 Deluxe 1998
Benelli 500 LS 1979
Velosolex 3500S 1968
Jaguar X type 2005
not forgetting SWMBO's Z3 2002
Reply #1 on: August 01, 2020, 02:22:29 pm
Check the rubber intake hose for small cracks or leaks.
They fail regularly from modern fuels, and a small leak causes lean mixture, which can in turn cause a spitback that blows the carb off.
Ask me how I know!
Home of the Fireball 535 !
Black fingernail
Reply #2 on: August 01, 2020, 03:07:05 pm
Ask me how I know!
Yes, I checked that, I think it is the clamp that doesn't seem to do-up very well.
I fitted a new rubber this spring, and at the time thought the clamps were a bit dodgy.
I don't know if it is me, but after lockdown, the quality of regular unleaded petrol seems to be a bit rubbish. I haven't touched the timing or mixture screw or anything, but hill climbing, two up, causes a bit of 'pinging', I ran the tank down as low as I dared, and filled up with Vpower zoom juice. No more 'pinging', I have run this for a bit, there is no other difference, performance wise, so I've filled up on regular, just to see if it is my imagination, there is just a bit, barely detectable, 'pinging' two up, and it's just popped the carb off. So... I know these are supposed to run on the most rubbish fuel imaginable, but, I think I'll just use the allegedly good stuff from now on.
Benelli 500 LS 1979
Jaguar X type 2005
AzCal Retred
Reply #3 on: August 01, 2020, 04:22:04 pm
As Ace says the factory spigot rubber is rubbish. Mine is showing cracks (again) at 3 months. I keep seeing radiator hose mentioned as a spigot rubber substitute. What's a good place to look, NAPA Auto? Any part number references? -ACR-
Reply #4 on: August 01, 2020, 04:33:31 pm
You just have to go into the store like Autozone or whatever, and get a piece of straight generic hose that they sell by the foot.
1.25" I.D. should fit the stock system.
Black fingernail
Reply #5 on: August 01, 2020, 05:16:49 pm
The rubber failed on mine in spring, I fixed it with a piece of car radiator hose, to get me home. There was a cone air filter fitted with no support, so I ran about a bit using the piece of radiator hose that got me going again. I then fitted the British made (better quality) rubber from Hitchcocks, I have also fitted a proper filter box that supports the other end of the carb. I still keep the hose in the tool box though, just in case.
Benelli 500 LS 1979
Jaguar X type 2005
Adrian II
Reply #6 on: August 01, 2020, 06:08:14 pm
I had a BSA B40 that would do this with aftermarket carbs fitted in rubber mounts!
A.
DavidGraves
Reply #7 on: August 01, 2020, 07:08:37 pm
Not Embarrassing in the least...I distinctly remember a young man who would bend over the petcock and motor of his 750-4 as if to doodle around with the timing on his friends duo-glide.
IT was just something one did if you wanted to impress the onlookers outside the saloon (nah...McDonalds)....
Besides the behavior there were all the requisite devices like the tiny little slip lock pliers that would fit in your watch pocket.
I can't remember that kids name.....
axman88
  • Vintage Motorcycle Fan
Reply #8 on: August 01, 2020, 08:26:40 pm
My buddy told me that the coolest thing to do when he was riding his Jawa, back in Poland in the late 70s, was to sit astride your machine, smoking a cigarette.  As you took the last puff, you'd casually reach down, take off the gas cap, and with a flourish, toss the smoldering butt into the tank.
AzCal Retred
Reply #9 on: August 02, 2020, 12:00:01 am
Ace - any advantage to making the connector stub longer? How about upstream of the carb, should there be 4" - 6" of intake tract? Or maybe none of it really matters until you pump-up the motor a bit?
I run a clamp-on K&N because I had dirt intrusion from the standard air box and it was bulky. I rejetted/lower # slide using the Hitchcocks guide. It seems about the same, performance wise, but a bit better off idle. I recall lots of Japanese machines are very unhappy with clamp-ons and stock carbs, but those were usually making 1 1/2 - 2 BHP/cu. in. or so.  -ACR-
