Author Topic: MV Agusta 2020  (Read 144 times)
Joe_535i
on: August 01, 2020, 07:40:41 am
The 2020 Superveloce, and the Magni Filo Rosso replica. Which one would you choose?   :D
The engine is apparently the same, the Superveloce might handle a tiny bit better and got more gadgets for sure.
Just to clarify, the Magni is equally streetable machine, remove the yellow number plate and you will find a traditional 7" inch headlight underneath.
« Last Edit: August 01, 2020, 07:43:10 am by Joe_535i »
GlennF
Reply #1 on: August 01, 2020, 08:37:57 am
For a second there I thought you were referring to yesterday's Superbike racing controversy with MV Augusta being disqualified from the Australian round:
https://www.mcnews.com.au/mv-agusta-riders-disqualified-from-phillip-island-results/
Following an investigation, the MV Agusta Reparto Corse team’s results from Phillip Island will not stand due to an unintentional engine infringement.
On July 30th 2020, the FIM World Superbike Stewards received a report from the FIM Superbike World Championship Technical Director, stating that some engines belonging to the MV Agusta Reparto Corse team were unsealed without prior permission after the Yamaha Finance Australian Round. This is an infringement of the 2020 FIM Superbike, Supersport and Supersport 300 World Championships regulations and specifically, article 2.3.10 in general and paragraph d.
FIM WorldSBK Stewards understood that the team’s act didn’t occur with an intention to make an infringement nor to gain an advantage in any way. This was more of a visual mechanical check and the result of a miscommunication.
The team brought it upon themselves to contact the FIM about the issue. Nonetheless, the process was not performed as per the Championship regulations and therefore, article 2.3.10.d is very clear and must be applied in any case.
For the above reasons, the Stewards, in accordance to the FIM Disciplinary and Arbitration code, have decided to penalise the team with the disqualification from all events in which the below engines have been used 2 from Randy Krummenacher and 1 each from Raffaele De Rosa and Federico Fulligni.
