Author Topic: Fork preload adjusters  (Read 27803 times)
Starpeve
  • Starpeve
  • Adelaide, South Aust- Conti GT 650 2019
Reply #30 on: July 04, 2020, 01:36:09 pm
Part 23? I think they're the damper rod bolts. Suppose there's no reason you couldnt drain the oil through them, though. I'd never though of doing that. You'd just need the tool to hold the rod from the top (sharpened broom stick works for me...)
Dion from Yam Retro printed that off for me and implied that it was merely removing the bolt . I hope he’s right cos I’m lazy👌
I’d rather have a bottle in front of me than a frontal lobotomy...
gizzo
  • purple people
Reply #31 on: July 04, 2020, 01:41:59 pm
I'm lazy too  ;)
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #32 on: July 04, 2020, 10:48:08 pm
That't the bolt that holds your fork's damper rod in place!!! Seriously, I just installed a set of cartridges in mine. One of these bolts came right out with an Allen wrench. The other one required an impact wrench and jamming the tube inside the slider with a really long screwdriver. Otherwise it would simply spin. There's locktite on it from the factory.
You don't want to take that out unless you are dismantling the forks.
NVDucati
  • USA 2020 INT
Reply #33 on: July 04, 2020, 11:39:37 pm
I just found out that their ARE drain holes in the forks! You take off the wheel and there’s a drain screw in the bottom of em 👍
WARNING:::
Those ARE the dampening cone bolts.
You might have a problem getting them re-tightened to spec without the cone just turning away inside.
It can be a real hassle.
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT, '14 Honda CB1000-R
Starpeve
  • Starpeve
Reply #34 on: July 05, 2020, 09:25:55 am
Buggerit! Another dream shattered!
Starpeve
  • Starpeve
Reply #35 on: July 10, 2020, 10:39:59 am
Thanks everybody for your(scary) feedback!! I guess that drain option has flitted out the window😬
NVDucati
  • USA 2020 INT
Reply #36 on: July 10, 2020, 12:32:01 pm
I have never tried it... but ... you could could consider a metal "straw" and a pump.
Member: AMA
Starpeve
  • Starpeve
Reply #37 on: July 11, 2020, 08:47:10 am
Sorry I tried to work out how to send that link but it’s beyond me!😳
Got a link? I might try these as well.
Breezin
  • 2019 Interceptor, 2021 R NineT
Reply #38 on: July 11, 2020, 10:29:28 am
Re sag, bounce, weave etc... interesting take on data vs. feel   https://advrider.com/dont-be-a-spreadsheet-warrior/
Starpeve
  • Starpeve
Reply #39 on: July 11, 2020, 12:17:36 pm
Nice article and quite apropos
Starpeve
  • Starpeve
Reply #40 on: July 11, 2020, 03:21:14 pm
Just worked out how to do it- sorry I took so long
https://www.ebay.com.au/itm/322486741850
SandSquid
  • Seattle, Washington
  • 2020 INT650 "Orange Crush"
Reply #41 on: July 11, 2020, 04:56:11 pm
That article is me to a T. I've only had my bike a full week and I've read so many things that "should be changed" that I've started doubting my own opinion that I love how the bike feels with just a simple rear shock adjustment. I'm my own worst enemy that way.... Okay, I'm going for a ride, I really do love how she is right now!
“It follows then as certain as that night succeeds the day, that without a decisive naval force we can do nothing definitive, and with it, everything honorable and glorious.”
- President George Washington
Starpeve
  • Starpeve
Reply #42 on: July 12, 2020, 08:36:08 am
It’s true, isn’t it? I know that I’m banging on all over this forum about mods, but it’s not because she needs em. It’s just in my nature. I’m doing nothing that isn’t reversible if it’s no good.
I love her how she is, just want to tart her up so my mates lust after her!!😂
Bumbo
  • Interceptor 650 Twin owner
Reply #43 on: July 17, 2020, 06:54:55 am
I thought they might, since they look much the same as the others. Just a matter of waiting for them to arrive. By that time, I'll probably have changed the fork oil, as suggested.
PS: Did your mate get them on without bar risers?
Did the yamaha pre-loaded adjusters work
beagle
  • Australia
Reply #44 on: July 17, 2020, 08:57:08 am
Ive ordered the same back in early June. Paid the bit extra for tracking and I've tracked them from the seller to the airport to .....return...reason...security check....That was nearly a month ago....simply disappeared....I'll wait another couple of weeks and start chasing them up.  Going to stop getting stuff outta china....service is turning to crap.
Drink now....avoid the Xmas rush.
greetings from Brisbane, Australia
