Author Topic: Ohlins suspension  (Read 5862 times)
twocoolgliders
  • Cookie
Reply #15 on: July 01, 2020, 10:47:24 am
I agree!   Both that the slight length difference doesn't matter, and that the K tech shocks are way overpriced for essentially the same thing a YSS.
I just went with the recommendation of the Guru.  (there I said it again...guru, guru guru!!!)
YSS front end probably is great too....but not fully adjustable...
Cookie
I noticed too that there were different lengths. And as my YSS are length adjustable so did the same.
K tech are good but double the price of the YSS G Series. Mmmmm are twice as good or paying a lot for the name? I dont know but if anything like the YSS you will be stoked.
I also have the Fork kit from YSS which is excellent
twocoolgliders
  • Cookie
Reply #16 on: July 01, 2020, 10:59:38 am
Agree about the length difference....not an issue...
Guru
[ goo r-oo, goo-roo ]
SEE SYNONYMS FOR guru ON THESAURUS.COM
noun
1) Hinduism. a preceptor giving personal religious instruction.
2) an intellectual or spiritual guide or leader.
3) any person who counsels or advises; mentor: The elder senator was her political guru.
4) a leader in a particular field: the city's cultural gurus.
Definitions 2, 3, 4......perfect use of the word by me!  (and I like the first pronunciation, 3 syllables!)
Ron at Washington Cycle Works is certainly an intellectual leader, as he has many many years of suspension experience and success.  He also counsels, and give advice.    Since I am ignorant and he is all knowing...he is my mentor on this subject.   His reputation is known far and wide, on suspension...so he is in fact, a leader in his field.
Guru !!!
And yes, there is even a religious sort of component to motorcycle stuff, like suspension...full of contradictions!
And just like with religion, you may note a hint of skepticism in my posts!
Cookie
I doubt that a couple of mm is going to make any difference. You’d probably get that in the bushings. And I’m really starting to dislike the word ‘guru’. I’ve met so many experts on so many things that totally contradict each other. A bit like religion when you pause to think about it....
gizzo
  • purple people
Reply #17 on: July 01, 2020, 12:33:12 pm
Friends, this is bullying. Stop the bullying please or I'll have to report you.
It's called trail braking and is used a lot by people that actually run the track.
You can learn a bit about it here:
https://www.youtube.com/watch?v=gPE67XqGsV4
https://www.youtube.com/watch?v=iZWac8OyYV0
GT 650 is really twitchy when transitioning from brake to throttle, that's why I'm looking into the better suspension.
If you have nothing to contribute, please do not harass and bully me.
Thank you.
You go right ahead and report away, little fella. I've included a report form for you to use as an attachment.
Please enlighten me as to what part of my post you consider bullying. Was it where I suggested you consider some rider training? Or where I offered advice on braking in corners? Perhaps it was the part where I advised you,  through practical experience, that front and rear chicken strips might not match due to the tyre profiles used on this bike. Or that using chicken strips as a metric of rider ability is a rookie error founded in ignorance and misplaced pride? Admittedly I do like having no chicken strips, it impresses noobs. Maybe I offended you when I suggested you watch the seminal riding skill video "a twist of the wrist" or Dave Moss' suspension tuning channel on YouTube.
Thanks for your advice regarding trail braking.  I am actually aware of and practice this method. I participate in track days average once a month,  as a rider and administrator. I've invested in roadcraft courses to improve my road riding and racecraft courses under the instruction of BSB and IOMTT racers and I consider myself a moderately fast, and safe,  road and track rider. So I'm good in that department, thanks. How about you? I prefer to Not advocate trail braking on the road unless a rider is proficient.
But,  what do I know? If you think spending big bucks on aftermarket suspension will address your shortcomings as a rider,  more power to you.  Perhaps I'm wide of the mark and you're a highly skilled racer trying to lower lap times. More likely big noting yourself  to impress the Enfield  community for reasons known only to you. Good luck and all the best.
« Last Edit: July 01, 2020, 01:32:06 pm by gizzo »
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
dcolak
Reply #18 on: July 01, 2020, 01:53:10 pm
Here are good videos on how to replace front and rear suspension, also the comments on riding experience afterwards.
Front
https://www.youtube.com/watch?v=pCywpE9fwnA
Back
https://www.youtube.com/watch?v=5cFuNIbicXg
Riding comments
https://www.youtube.com/watch?v=hmxk6NJBQjg
Exactly what I'm expecting out of it, wheels keeping contact with road at all times.
Didn't find more info on Ohlins and K-Tech. If anyone has more info, please share  :)
Triumph 800XC, Royal Enfield 650GT
Jako
Reply #19 on: July 01, 2020, 02:15:54 pm
I'm not sure what that would accomplish  ??
I asked this question specifically, (because you mentioned this before)
Suspension Guru tells me that is a bad idea...he didn't explain why, other than it can really fuc-up the bike...
The major problem that he diagnosed, (on my specific bike) was poor rebound damping on the front.  The bike, when he tested, will "bounce" about three times, up and down...should go down, then rise up....that's all..
Raising the bike at the front end will not help with this.
The Guru says we will most likely end up with the bike sitting with a slight "rake"..that is, a hair high in the rear compared to the front...(not the other way 'round)
He also went on to tell me the story of a crazy kid who came in with all good equipment installed on his sport bike, but all out of whack settings and fork height...he told the kid to make an appointment to get the bike set up properly...he told the kid not to ride the f-ed up bike...he made repeated phone calls to the kid...who ignored....then two weeks later...kid looses it in a turn...dead....
Really, probably not the fault of the bike..kid most likely just too crazy...but a word or warning to not f-up what you don't understand....
just sayin...
Just to be perfectly clear....I am not a "hard" rider....A super set-up suspension is completely wasted on me.   I am going for a super-comfortable, street ride....for my old-man style of riding...."comfort over performance"...
The Guru says this is completely do-able....to make a great riding, great handling bike...but set up for my style of street riding...
This is the main reason I went with full adjustable front and rear suspension and pro set-up!
It has also become a "learning experience"   just for the fun of learning...I'm sure the cost will not be "worth" the results...but...
We shall see...
Cookie
dcolak asked about twitchy feeling mid corner.
Gee I thought everybody used the fork height and rear shock length to fine tune handling  characteristics after setting sag and rider height.  Seemed to correct twitchy  mid corner stability  for me.  Seems Iv been f-ing up something I don't understand for the last 45 years , must be lucky I guess.
« Last Edit: July 01, 2020, 02:50:56 pm by Jako »
2020 Rav Red Interceptor (wife's bike) ,Interceptor 2019 bakers express ,  2021 Honda cb500X, 2021  euro4 Himalayan (wife's)
dcolak
Reply #20 on: July 01, 2020, 02:19:35 pm
Thanks man. That's exactly what we are talking about. I have no idea why so many people here start bullying when you mention trail braking, lean angles and high revs.  ???
Jako
Reply #21 on: July 01, 2020, 04:16:15 pm
dcolak
I'm sure ill be flamed for this advive as Im not a suspension  guru, just a retired coal mine mechanical  fitter and   shouldn't be giving advice and f-ing up stuff I apparently don't understand . I believe  the original set up of these forks were downright dangerous  but could be much improved  for about $20,  simply  remove forks, drain oil and change to 15w ( I used penrite 15w synthetic   fork oil)   fill to 140mm from top ( fork compressed and spring out). Then add more preload to the springs depending on your weight   start with about 8 mm   ,( I set rider sag to around 30mm) either make new spacer tubes or add washers of approximately  35mm OD under the caps. I found this a huge improvement and much safer handling  but I eventually upgraded the springs and valves to better suit my weight .
twocoolgliders
  • Cookie
Reply #22 on: July 01, 2020, 05:02:12 pm
See another post regarding "religion"
Cookie
dcolak
Reply #23 on: July 01, 2020, 05:44:04 pm
dcolak
That's what I noticed, it gets really strange mid turn, god forbids you are running over road that is not perfectly flat.
Thanks for the suggestion!
Starpeve
  • Starpeve
  • Adelaide, South Aust- Conti GT 650 2019
Reply #24 on: July 02, 2020, 02:40:25 pm
I think the clues are in the’guru’ and ‘ignorance’ comment. Gurus feed on ignorance or more precisely naivety. Anyone that tells you these bikes handle terribly is conning you. Sure, they may not be trackworthy, but come on- they handle at least as well as the bikes in my 45 years of riding have. Probably better. And Colac or whatever your name is, you seem to imply a throttle off- brake on- throttle on style of riding. Wrong bike. Smoothness is everything- Joey Dunlop would tell you that . Years of riding old Ducati’s taught me to favour the rear brake to conserve the front tyre profile. Once you got any squaring of the front tyre they handled like shit. Pick your line, ride the rear brake, feather the front, power out of the apex. Old time bikers would cream over this bike. I’m so happy with mine that I crave every moment on it.
I’m going to play around with modding it but that’s just me. Not any shortcoming of the bike. If you’re unhappy maybe you should get a 170 hp jap screamer.
I’d rather have a bottle in front of me than a frontal lobotomy...
twocoolgliders
  • Cookie
Reply #25 on: July 02, 2020, 04:21:06 pm
I'll tell you that "my" particular RE650 handles terribly.....I don't know about  anybody else's...but mine bounces down the road.  I have had 9 other bikes that didn't bounce down the road...but this one does....
If you do a simple test of the front end...you can see that it "rebounds" at least three cycles....poor rebound damping...
Many "fixes" have been suggested....I guess most or all will work to some degree.
I've decided to go with a fully adjustable cartridge kit...
I don't care about "race bike" handling, I am just a "cruise around" type of rider...I just don't want to bounce...especially in curves.
I'll let you know how it turns out.
BTW...you know nothing about Ron at Washington Cycle Works  (the "guru")...so maybe you should not make any assumptions?
Just sayin'
Cookie
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #26 on: July 02, 2020, 08:59:21 pm
Well said! The main factor in smoothness is the rider. He is attempting to compensate with hardware.
dcolak
Reply #27 on: July 03, 2020, 09:07:06 pm
I am not following you. Why would my tyre be square? I am actually using its full profile.
On my Triumph 800XC it's oposite. My front tire is never used completely but my back tire is ridden to the limit of its profile.
It's just interesting. I guess it has to do something with the width and radius of the tires.
GT 650 is 100/90r18 : 130/70r18
Triumph 800XC is 90/90r21 : 150/70r17
Starpeve
  • Starpeve
Reply #28 on: July 03, 2020, 11:18:39 pm
I was referring to your statement about Twitchiness when transitioning from brake to throttle. And the squaring was merely referring to the style I learned to adopt to conserve front tyre profile. Went a little sideways there sorry!
gizzo
  • purple people
Reply #29 on: July 03, 2020, 11:33:05 pm
That was pointed out to you and you complained it was bullying.
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
