Author Topic: throttle and grips  (Read 134 times)
Stogierob
on: June 28, 2020, 08:34:22 pm
what throttle & grips should I use for a 1940's look?
thanks
Rob
1977 RE Bullet 350 that is slowly being converted to resemble a WWII era bike...
Bilgemaster
  • Just some guy
Reply #1 on: June 29, 2020, 12:52:12 pm
Good to see you're at your warhorse again, Stogierob. Rummaging through Google Image Search offerings for those few color photos of wartime Enfields, it seemed some had what look like regular black rubber handgrips while others had some sort of brownish material with what appear to be metal end caps. And then I stumbled upon this webpage, which I'm sure you're gonna love: https://hollycat2000.jalbum.net/REMP2016/Personal/WD-CO/custom/index.html .
Here's a relevant excerpt:
"Early models were fitted with rubber handlebar grips, but later on in the war, rubber became scarce and canvas was used for the grips instead. Original canvas grips are very hard to find these days, so if you can't locate a pair on autojumble stands or via adverts, you can always have a go at making a set. They were originally made from a tube of Canvas but a good alternative is one of those old Army Side Packs, cut a piece of canvas and glue it to the handlebar or twistgrip. If you take care and make a butted joint with a razor blade, making sure it is at the bottom, you can't tell the difference. The biggest problem are the two rings on either end of the grip. A lot of these rings are made of Brass, but I've also seen plain metal ones. My brother is a plumber, so I managed to get some copper tubing that was a tight fit and it looks OK to me.
If you do find an original grip, bear it in mind that the WD/CO had 7/8" bars, other bikes like Norton used 1" diameter bars and you can also find 7/8" grips that are 6" long, so make sure you have the right size."
And here's an image from that article:
« Last Edit: June 29, 2020, 12:55:51 pm by Bilgemaster »
So badass my Enfield's actually illegal  in India.
Stogierob
Reply #2 on: June 30, 2020, 08:52:26 pm
Thanks!
That’s an incredible link for RE history.  I really appreciate it.  I have plenty of that canvas available to fashion my own grips.  I like that idea, since my bike isn’t a beauty queen in any respect.  Having ‘field created’ grips will be very appropriate.
It’s nice to be working on the bike again.  I had a friend over and we did a complete top-end rebuild, except for the valve guides.  I make a half hearted attempt to get the old ones out and decided it wasn’t worth it.  Now if it’s leaking oil from anywhere, it’s only from the lower half of the engine.  Progress comes in many forms.
Now back into he garage to finish relocating the ignition switch to the left side tool box.
Rob
Bilgemaster
  • Just some guy
Reply #3 on: June 30, 2020, 10:17:31 pm
Glad to help! If you happen to have a common white or off-white greyish canvas on hand, you could try soaking it in a cup of very strong tea to dye it that brownish-beige or sometimes khaki color that one seems to often see in the color photos of such grips one finds online.
And do let's see some photos as you move along!
