Author Topic: 2019 Classic 500 Stealth, chugging, surging  (Read 169 times)
SARPLT
on: June 23, 2020, 08:41:39 am
Hi there,
I have a new Classic 500 Stealth, I have put about 2500 KM on it here in Brunei. I find it will chug or surge in second gear through most of its range unless I goose the gas. It has also started to stall or hesitate on acceleration unless I goose it as well. I checked the stock plugs, they seem normal also re-gapped them and checked and adjusted the clutch cable assembly.
It went away or reduced for a bit but now its back......
Cheers
W
2019 RE Classic 500 Stealth Black. Straight engine guard, no pillion, bar end mirrors and soon to have a flip cap to round cap conversion...
heloego
Reply #1 on: June 23, 2020, 03:44:37 pm
Any MIL codes?
'12 C5 Classic
heloego
Reply #2 on: June 23, 2020, 03:55:02 pm
Welcome to the forums!
MIL codes can be your friend and a good place to start.
Then check all the connectors on, and from the ECU to everything else and verify good connections.
Check that the small black ground wire at the Negative terminal of the battery hasn't broken. It will often break inside the insulation and not be immediately apparent.
There are some excellent videos on YouTube that may help.
https://www.youtube.com/results?search_query=royal+enfield++MIL+Codes
If you could post a video or sound clip to the forum it might help us a bit more.
'12 C5 Classic
SARPLT
Reply #3 on: June 24, 2020, 12:27:53 pm
No Mil codes, I will check the battery and re-gap the plugs and take her for a ride later this week.
Thanks!
SARPLT
Reply #4 on: June 25, 2020, 11:46:54 am
I do have a metalworks exhaust, I may need the air injection delete kit.....
