Author Topic: larger tires....is it possible or no?  (Read 2891 times)
NVDucati
  • USA 2020 INT
Reply #105 on: October 17, 2020, 10:23:40 pm
I bought the Avon Roadriders
110/80-18
150/70-18
The front will be shorter than the rear, not sure if that;s a problem or not.  I guess it will give be more aggressive turning, which is good but if it will ruin the smoothness I'm not sure.
https://www.tacomaworld.com/tirecalc?tires=110-80r18-150-70r18
Those measurements don't exactly match the ones given on the Avon site, but close.
I'm sure that those MKII will make you smile. (you did get the newer MKII, right?
Curious, did you enter the OEM sizes into that calculator?
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT
Bagonne
  • Hudson Valley, NY
Reply #106 on: October 18, 2020, 12:20:54 am
Yes, am26. The OEM sizes are equal heights. What do you think about the lower front?
NVDucati
  • USA 2020 INT
Reply #107 on: October 18, 2020, 01:05:59 am
Keep going _ you'll love it.
Member: AMA
Bagonne
  • Hudson Valley, NY
Reply #108 on: October 18, 2020, 02:04:15 pm
BTW, it seems I got MkI road riders, it's all I could find, had to use Ebay and amazon.  I'm sure they will be miles better than stock.  If the shorter front turns out to be a bust I'll replace it with a MKII 110/90 when available.
I have no idea why finding tires in these sizes is so difficult in the US but it is.  Time to move on
As a friend said many times, Live and Loin
« Last Edit: October 18, 2020, 02:09:45 pm by Bagonne »
