Author Topic: My poor '06  (Read 294 times)
aBeardedWeirdo
on: May 29, 2020, 05:19:23 am
Recently got a 2006 Bullet 500ES from out front of a shop that closed it's doors for good and was using the bike at the end of the road as a display. Hoping for $150 well spent
Pulled the engine and the big end is TOAST. Not much good in the engine in general.
Hoping to scour this site for knowledge and ideas.
Trevor
Reply #1 on: May 29, 2020, 06:31:25 am
The conrod/big-end/piston are all junk from the factory anyway.
Do a competent rebuild with a steel conrod with Alpha roller big-end, a Hitchcock 8.5:1 piston in a new alloy barrel(not the cast iron stocker) properly bored/honed to .0055" clearance, retard the stock intake cam only by one tooth counterclockwise(leave exhaust cam in factory position).
The other parts should be okay to use.
That is the recipe.
Adrian II
Reply #2 on: May 29, 2020, 01:43:51 pm
You might want to add some high-quality main bearings to the rebuild mix too.
Ace, is the Fireball conversion still available for owners of C.I. Bullets in the USA? This motorcycle sounds like a prime candidate. I know your efforts are concentrated on the CGT these days.
Reply #3 on: May 29, 2020, 05:03:52 pm
Adrian,
Chumma is still doing them on request. I still have some parts. We have a new machinist that is willing to do our work, so Iron Barrel Fireballs could be coming back with increased demand.
Adrian II
Reply #4 on: May 29, 2020, 05:10:57 pm
Yay!
aBeardedWeirdo
Reply #5 on: May 30, 2020, 03:49:02 am
Talked to Chumma on the phone for quite a while today. Things are looking positive.
Reply #6 on: May 30, 2020, 11:58:59 am
Yes, he called me about it yesterday.
Welcome aboard!
Royal Stargazer
Reply #7 on: June 17, 2020, 04:28:50 am
If iron barrel fireballs are coming back, is there hope for Ace air canisters?
What's the state of the iron barrel right now? I feel like I've seen more demand for them, but I also may be looking at a sample too small to illustrate the big picture.
2003 Royal Enfield Bullet, velvet green
2001 Mazda Miata LS, sunlight silver
Reply #8 on: June 17, 2020, 05:34:47 am
Air canisters are discontinued.
Sorry.
JVS
  • I love chicken
Reply #9 on: June 17, 2020, 12:55:48 pm
My offer / willingness to get you to make an Ace Canister for my UCE B5 is still open also!
Happy to negotiate a higher price if that makes you bring the Ace Canister back  8)
Paul W
Reply #10 on: June 17, 2020, 03:55:16 pm
I've no idea what an Ace Air Canister is...but I'm sure I need one..!  ;D
PW.
Adrian II
Reply #11 on: June 17, 2020, 07:30:09 pm
It was a custom air filter used on the Fireball Bullets, A vertically mounted cylindrical thingy with a horizontal rubber pipe to the carb, usually a Mikuni flat slide TM32-1.
I'm sure Ace or a Fireball owner can come up with a picture.
Reply #12 on: June 17, 2020, 09:03:39 pm
Here is a photo of a Bullet with an Ace Air Canister on its Mikarb 28.
I also made them with a larger connecting hose for a Mikuni TM32.
Maybe if we can get a few more people together, I can make a small run of them as special order.
« Last Edit: June 17, 2020, 09:09:37 pm by ace.cafe »
Paul W
Reply #13 on: June 17, 2020, 09:57:19 pm
Aha, thanks! I fitted an oiled foam, cylindrical filter to my 350 when I gave it a 26mm concentric type carb. I already had a “K&N” cone type filter for it but when the new carb arrived it had a screw on ram tube already fitted and I wanted to keep that. The foam filter fits neatly over it.
I also have two spares; I’d bought them to go on a triple throttle body car engine project which I didn’t go ahead with because I designed a supercharger setup for that instead.
PW.
