Author Topic: Outer Gearbox Removal - Adjuster Plate Assembly  (Read 1696 times)
AzCal Retred
  • Chennai Wrencher
Reply #15 on: July 07, 2020, 08:21:33 am
My kickstart went belly up, and a new pawl didn't fix it. I ordered a new gear & pawl spring, and a kickstart shaft as well as mine had a spiral crack. The new gear did the trick. It didn't look like a lot of wear on the old gear, but it was noticeable when compared to the new one. I set my KS lever as far forward as I can to get as much "bite" on the crank stroke.
