Author Topic: Int 650 exhaust outer diameter  (Read 1213 times)
dougodewitt
  • 2019 INT650 Baker Express
on: October 28, 2019, 01:54:25 am
I'm shopping for an aftermarket exhaust, but nowhere in the handbook or the service manual does it give that dimension. I need to know what diameter slip on to buy. Thanks for your help!
RIDE, ride, NOW! Ride!
heloego
Reply #1 on: October 28, 2019, 08:53:01 pm
I don't have a 650, but...
Measure the outside diameter of your pipe(s).
Any silencer you order should have a minimum inside diameter larger than your measured OD. The closer the better, but always larger.
Most, but not all silencers ordered should come with a set of two or three adapter rings so you can get a good fit.
'12 C5 Classic
Adrian II
Reply #2 on: October 29, 2019, 01:09:51 pm
You could try measuring the pipe diameter.
A.
Cat3625
  • My need for speed
Reply #3 on: November 01, 2019, 08:06:15 am
Pipe pipe size 45/46 mm diameter
1966 Continental 250 GT
2001 Bullet 500 k/s
2002 Bullet 350 Trials
2008 Bullet 500 Classic electric start
2016 C5 Military 500 efi
2019 Interceptor 650
U.K.????????
