With a bit of checking around on the Internet. One might find that prices have come down quite a bit for PC-V's and an Autotuner AT-200 for the UCE's. The price difference NOW , between a full Carb conversion vs sticking with EFI and a fuel controller are pretty darn close . The difference in installation of the two options are probably on par with each other ... Some plugs to plug in and wires to attach , and a threaded bung welded on your head pipe with a PC-V and an auto tuner. Vs cables and hoses and clamps on a carb and etc. The PC-V and auto -tuner wins hands down IMHO , because it is infinitely more tune-able , more accurate , and easier to tune then a Carb could ever be. Easy to set up with a lap-top or PC with very basic computer skills. And once set up.. it will adjust automatically to what ever intake ,or exhaust mod you put on that bike . There will be no guess work involved and wondering about your plug color at what throttle opening and etc. It will just adjust your fueling to the air fuel ratio that you want, after a couple/few rides of the bike. And SO much more should one want to use the other features on the PC-V with more advanced mods. Tuning with Fuel injection , you are tuning to the actual and exact air fuel ratio in every throttle position and RPM range. It is sooo easy now , it is like cheating....
An example below of target air fuel ratio's that I have found work well on these bike's. This is with our 10 % Ethanol fuel that we have here in the States. 93 octane Shell super. YOUR local fuel may vary. Try getting this accurate with a Carb .
And BTW, if one DOES adjust their fueling in this manor , like you see in the example. Be mindful that the stock EFI system cuts fuel as it's rev limit at around 5500 RPM's. So if one WERE to tune in fuel ABOVE that 5500 RPM stock rev limit ?... One might go BEYOND that stock rev limit. So be careful
. A stock bike with just an intake mod and and exhaust mod should not need to go above the stock limiter anyway , as your power will likely be falling off before then. Just because you CAN rev it higher then the stock rev limiter, does not mean you are making anymore power. It's just a waste and over taxing you motor for no gain. Cam's , head work, more freer flowing exhaust and intake and etc. may justify a higher rev limit though...
