Author Topic: Accessory Socket  (Read 1355 times)
rmdba
on: October 12, 2019, 09:59:24 am
I've just spent a while putting heated grips on my Interceptor, and took the switched power feed to the relay from the pilot light in the headlamp. It was only when I finished that I noticed a spare connector in there. Looking at the wiring diagram, I see it's a switched accessory socket, rated at 10A.
So, if you're thinking of adding electrics, just be aware that there is already this connector for you to use. Yes, it's only 10A, but that's probably enough for sat nav, heated grips etc...
The lesson for me is RTFM !!
Vintageman
Reply #1 on: October 12, 2019, 05:30:35 pm
Any word on the alternators total output? I saw an initial post but no follow up. Hope to get any info on heated clothing use with these bikes. Thanks.
Reply #2 on: October 12, 2019, 05:40:57 pm
The technical specs in both the service and owners manuals I've seen say 156 Watts @ 1100 RPM.  Does that help?
Vintageman
Reply #3 on: October 12, 2019, 06:01:45 pm
Thanks, at idle, but wondering what max output is. It's low for a modern machine at that number. Typically would like to see in the 400 watts range. Rare earth magnets and a stator upgrade, but room for a larger stator may be an issue with this resto mod design. Concerned as I'm a 150 mile a day commuter and electric riding equipment is a necessity for me.  May be a deal breaker.
Reply #4 on: October 12, 2019, 09:40:49 pm
Sorry, don't know...
rmdba
Reply #5 on: October 14, 2019, 09:27:09 am
The 156W is as you say at 1100 rpm. That's not a bad figure at all for what is basically tickover. The output at higher rpm will be much larger. I read somewhere, but can't remember where, that RE are aiming the bike at the touring market, and so put on a huge alternator. I don't have any worries about the output, and I shall be using my heated jackets as well as heated grips, sat nav etc.
Mav
Reply #6 on: October 14, 2019, 07:19:07 pm
What type of plug (connecter)is the spare feed?
2017 Triumph Tiger 800 XRx
2019 Royal Enfield Interceptor
rmdba
Reply #7 on: October 17, 2019, 09:31:19 am
It's a standard 2 pin connector - afraid I don't know what they're called, but here's a photo.
bigm
Reply #8 on: October 17, 2019, 10:25:17 am
156 watts would be more than enough for chargind mobile phone and heated grips. My major concern is keeping the phone charged because i love cold.
Breezin
Reply #9 on: October 17, 2019, 02:29:58 pm
Thanks so much for this. I'd never have copped it myself.
Dr Mayhem
Reply #10 on: October 17, 2019, 06:38:56 pm
I think something a lot of us would do, so very good to know beforehand! Thanks  :)
Guy
19 Conti GT in Dr Mayhem paint 08/24/2019
06 HD Street Bob
04 Buell XB12S Lightning
Mav
Reply #11 on: October 17, 2019, 11:11:09 pm
Thank you.
Very useful info  :)
EnfieldGuy
Reply #12 on: November 13, 2019, 08:30:19 am
Its nice to see Enfield fitted this accessory socket on these bikes, I have fitted a USB outlet to the free socket and mounted this USB outlet to the top of the main tube on the forks, I then just run a charger cable to my phone on longer rides going to a little magnetic tank pouch! Works really well.
hadujorganic
Reply #13 on: November 17, 2019, 12:14:07 am
Is that the actual accessory connector from the headlight housing?
2019 Royal Enfield Interceptor 650
rmdba
Reply #14 on: November 18, 2019, 10:36:47 am
Yes, it's inside the headlight. Just pop the front off, and you'll find it in there.
