Author Topic: tire/gearing change calculator  (Read 588 times)
Dr Mayhem
on: September 27, 2019, 10:12:08 pm
Look for "Royal Enfield" then "Interceptor"
https://www.gearingcommander.com/
(Edited August 8, 2020 to update link)
« Last Edit: August 07, 2020, 12:05:06 am by Bilgemaster »
Guy
19 Conti GT in Dr Mayhem paint 08/24/2019
06 HD Street Bob
04 Buell XB12S Lightning
Dr Mayhem
Reply #1 on: September 27, 2019, 10:17:25 pm
I added 1" to the rear tire O.D. and 2 teeth to the trans sprocket, it slowed the motor down 854 rpm at 85mph in 6th @4799 rpm. Only 200 rpm off torque peak
These come with 6spd folks so row it like you own it :) huge step up over a 5spd and you can't even compare it to an antiquated 4spd
« Last Edit: September 27, 2019, 10:35:22 pm by Dr Mayhem »
Guy
06 HD Street Bob
Dr Mayhem
Reply #2 on: September 28, 2019, 03:00:29 pm
These bikes are geared for a theoretical top speed of 105 MPH
Based on 44 HP @6840 rpm, someone onboard my weight 165lb, with two teeth up (17) on the trans sprocket and under ideal conditions 115 should be attainable  ;D
Mileage falls off considerably cruising past the motor's torque peak of 5100 if you want fast commutes
My wife's 2010 Toyota Yaris with it's larger o.d. tires (about 1"),  1.5, 95hp motor will indicate 110, so in actuality probably a bit more,  :o  also more aerodynamic than they look I guess
Guy
06 HD Street Bob
Enfield Pro
Reply #3 on: September 29, 2019, 11:51:25 am
I may be confused but doesn't increasing the sprocket size on both the front and rear cancel each other out? To gain top speed I always thought up in the front down in the back.
Tim
2009 G5 Military W/Sidecar
USCA #9136
REOC Member
Dr Mayhem
Reply #4 on: September 29, 2019, 02:50:36 pm
You are correct, but a taller rear tire gives the same result as a smaller rear sprocket. In the case of a 130/80-18 vs a 130/70-18 it's an inch and results in 3.909% higher overall gearing. Specifically talking about a Conti roadattack radial here. Tire also raises the rear 1/2 inch for bit sharper steering. Steering a little slow on these bikes I think, at least compared to my Buell. Probably the stock tires contribute a lot also. win-win going to this taller tire on a GT I think
Guy
06 HD Street Bob
