Author Topic: Adjustable Pushrods  (Read 3497 times)
Bmadd34
on: July 15, 2019, 07:54:04 pm
I have done scoured the forum's search feature and googled to my heart's content, but cannot find a viable avenue for parts. Are there solid lifters and adjustable pushrods available for the UCE engine?
When Life hands you lemons, Squeeze them in his eyes and take his wallet.
Jako
Reply #1 on: July 15, 2019, 10:29:41 pm
Talk to gashousegorilla, he converts the hydraulic lifter to solid by fitting a aluminium plug into  the stock lifter body. He also has access to adjustable push rods to suit.
B5 2013 ,Honda CT110 2011, Honda C90 cub,  C5 (wife's bike)
Reply #2 on: July 16, 2019, 02:09:27 am
As mentioned, the stock hydraulics can be converted to solids, and various racing pushrods companies could make pushrods for you of correct length.
I would wonder what is wrong with the factory hydraulics?  We are getting 6500 rpm and about 38 rwhp with them as long as you have good valve springs.
Home of the Fireball 535 !
Bmadd34
Reply #3 on: July 16, 2019, 06:46:29 am
    Nothing is wrong with them per se, it is more about quitting the valve train. Throughout the rpm range, the hydraulic lifters allow for more noise at various pressures. A sild adjustable system would provide a quieter ride, with the option to adjust accordingly when needed.
Dalmatian man
Reply #4 on: July 16, 2019, 11:20:41 am
Why fix what is not broke, on a new engine as well.
33cc cyclemaster
James Cadet
James Comodore
Honda C50
Suzuki Gn250
BMW 650
Honda Hornet 600
BMW R1100RS
Royal Enfield C5 2014
BMW G310R
chuychacon
  • TEAM BANZAI 88
Reply #5 on: July 16, 2019, 03:23:50 pm
Solid lifters are good for making excuses, " Sorry cant do that I have to adjust my lifters"
Moto Guzzi Lemans 1980
Kawasaki 750 Twin Cafe 1982
Honda XL 350 older brothers age 18-20
Honda Dream 50cc hand me down age10-14
Reply #6 on: July 16, 2019, 09:03:11 pm
Your understanding is backwards. Hydraulics are quiet because they have no lash gap, and solids are inherently noisy because they must have a lash gap.
There have been many reports of some "clicking" noises on the UCE engines, but it is not down to the hydraulic lifters. I have never isolated the actual source of whatever top-end noises have been complained about in the stock UCE engines, but I suspect that some of these engines are assembled by the factory with insufficient lifter preload to handle the amount of vertical expansion that these engines have, so they clack when warm.
While our Ace UCE engines use a different rocker system, we use the standard factory hydraulic lifters and it has a silent valve train. The lifters are not the source of noise in these engines. Something else causes the noise.
Bilgemaster
  • Just some guy
Reply #7 on: July 17, 2019, 01:49:48 am
Just out of curiosity, did they also give you your old engine back to tinker with? 'Cause like Dalmatian Guy, tearing experimentally into a my sole and brand new motor wouldn't be my first impulse either...and most certainly not during prime riding season. But then, I'm quite sure your mechanical and engineering chops are more up to whatever you're up to than mine would be.
So badass my Enfield's actually illegal  in India.
Bmadd34
Reply #8 on: July 17, 2019, 02:53:10 am
    Unfortunately, they would not allow me to keep the old engine. They wanted to tear into it themselves.
GSS
Reply #9 on: July 18, 2019, 03:20:12 am
GHG has really nice push rods. Send him a PM.
2019 Himalayan Snow
2019 Interceptor 650 - Orange...off the first boat!
2014 GT - Red...lowest VIN off the first boat!
2010 C5 - Teal
1942 WW2 Willys MB Slat grill
1945 WW2 Willys MB
Bmadd34
Reply #10 on: July 18, 2019, 04:34:46 am
    I did, but he hasn't been on.
Reply #11 on: July 20, 2019, 02:11:57 am
  Sorry.  For some reason, I don't get email alerts anymore when someone PM's me ?  But you can get me at my email address under my profile anytime.    Happy to help and give an honest opinion.  ;)  And I have been a bit busy these last couple/few weeks , what with going over the handlebars on the highway,  getting some rest , subsequently fixing the bike and helping other guys out with their bikes.  ;D   I'm fine , don't ask.   Just a little scraped up and some sore ribs.   I  had forgotten how hard handle bars and  black top can be !?   :o ;D
 PM sent Brad.     And as far as I know ?  I'm the only one who has uses solids, around here anyway .   And yeah.. I can get adjustable rods easy, in different lengths , for different cams  , or for solids or hydraulics.  Oiled or not oiled and etc.
  As far as noise goes on these bikes with Solid's vs  Hydraulics, in my personal hands on experience with tuning and working on them for the past 8 or 10 years now ?     Solids an Hydraulics sound about the same.   Maybe actually slightly quieter with the solids , vs the Hydraulic's  .  You can judge for yourself though.  Check out Singh 5's channel on YouTube and you can listen to my bike running with solids yourself.  The valve train and top end noise comes from a lot of sources... one being the brass bush pressed inside the stock cams can be a bit out of round . FROM the factory.  And that adjustable eccentric  cam spindle ?    ::)    The  massively heavy stock rocker's coming down on the valve  tip and etc and etc.   Take a look see at the stamped steal rockers used with Hydraulics on a Chevy 350 small block  for instance and compare it to the pile driver rockers in our motors  !  ;D
   Anyway.... in my opinion.     Solids are always better for performance then Hydraulics.  EVEN if you are NOT reving it to the moon.   You will get better and more consistent valve timing with solids then you will with Hydraulic's.  Valve timing can vary a bit with Hydraulics , depending  oil viscosity, oil temp and oil aeration  and when that lifter actually locks going up that ramp.  I don't think we would have gotten 36  and 38 Horse power and ft pounds of uncorrected torque AT THE wheel , at around 5700-5800 rpm's by using Hydraulics on that 500 cc motor.  ;)   BTW, the 500's  Have a heavier crank then the GT.   So personally, I would not rev the 500's much past 6200 rpm's without some bottom end lightening and some work.     BUT.. solids DO take a little bit more to set up and you have to check and adjust your lash...  Obviously.  But better if you are trying to squeak every last bit out of that motor that you can, type of thing.    The Hydraulics are not that bad in these bike I have found, I have done well with them.  And you can keep them under control with better springs... or even just shimming the stock springs for that matter.     BTW, I HAVE had one of these motors up to 6700 rpms with shimmed stock springs and Hydraulics .... and a little PC-V cheating .  So the Hydraulics  are pretty good.
 Thanks GSS.  Just not from that ONE supplier out there !   Geez...  ;)
Bmadd34
Reply #12 on: July 20, 2019, 02:26:49 am
Reply sent GHG. Thanks for your input.
Reply #13 on: July 20, 2019, 12:34:02 pm
Not relevant to the subject at hand, but:
Me too...
https://forum.classicmotorworks.com/index.php/topic,27337.msg313328.html#msg313328
  • "What's He Building In There"?
Reply #14 on: July 20, 2019, 03:24:37 pm
Me too...
             Me also? Looong time me not notified.
'08 Black AVL Classic.ACEhead 9.8:1/manifold/canister. TM32/Open short bottle/hot tube removed. Pertronix Coil. Fed mandates removed. Gr.TCI. Bobber seat. Battery in right side case. Decomp&all doodads removed. '30s Lucas taillight/7" visored headlight. Much blackout & wire/electrical upgrades
