Having the carb dialed in correctly must help, and if I ever renew an ignition coil your choice of Pertronix Flame Thrower has been noted.Champion plugs now preferred too! Also, my old Electra-X's starter motor still sits forlornly in the garage, it's yours if the one on your AVL Classic ever goes belly up.
Should the need ever arise, I don't think retro-fitting one of the smaller 10mm decomp valves would be too much of a challenge, Ace seemed to think it was do-able when I discussed it with him some time ago. It has certainly been done with the CGT535 head.
Yes. I believe I'm pretty damn close on the carb dialing. Godknows I've spent enough time at it and experimenting. I get a good idle and really good, smooth road performance.
BUT, never satisfied, I've made a few changes that I will experiment with when it gets warm. I'm like a crippled up old turtle in the cold.
Right now (I mean last season), I get a good mixture at a bit less than 1 and a half turns out on the mixture screw (so the 27.5 Pilot must be OK) and I can idle it down suicidally low and it won't die (which I only do as an experiment). I NEVer dies on it's own. I quit worrying about that long ago.
So I've had the carb off and cleaned and petted, etc., and I have leaned the needle one notch just to see what happens. If it doesn't improve anything I will put the needle back in the middle notch as it was before. Also, because the plug is still a bit blacker than I like to see them, I'm going to try a 1 number hotter Champion plug, but only AFter the needle notch change experiment. The needle change may change the plug. Who knows?
The plug looked good/OK at the middle notch, but just slightly blacker than I like to see.
I also have bought a Gunson Colortune and cannot WAIT to play with THAT puppy
From what I read, I'll be able to tune from idle to mid-range in the garage using the colors and that's where I do ALL of my riding.
Much of my cold kick start problem I'm sure may be me (although it was already a problem in 2014). I've lost a lot of muscle strength plus it hurts like hell now and after 3 or four kicks I'm ruined if it hasn't started. Also I only weigh 124 now at 83 (Birthday March 5th). Also 9.8:1 comp.
