Author Topic: how to protect rubber straps  (Read 2162 times)
sjbiat
on: October 09, 2017, 02:47:18 pm
After only 3 years I found I needed to replace the sidecar suspension straps.  (Now I see why they are a best seller.)  I'm thinking of using WD40 specialist water resistant silicon spray on the new ones.  Supposedly it leaves a film.  Has anyone tried this?
stephan
09 C5 with Cozy sidecar now
formerly
97 Motoguzzi
94/02 Ural
85 BMW R80
64 BMW R60/Hollandia/Steib
61 BMW R69/Watsonian
60 Pugeot
Reply #1 on: October 10, 2017, 02:34:14 am
I haven't tried the WD40 specialist water resistant silicone but I can recommend something that works great on rubber and vinyl (and plastic).
It's called, AEROSPACE PROTECTANT® 303.
The label says "SPF40 For Your Stuff" and it works great.
With regular use it provides 100% protection from UV.
Ultraviolet light is one of the things that can cause rubber, vinyl and plastics to crack and fail.
I'm also sure it protects from ozone which is another thing that can break down rubber and vinyl.
I use it on the vinyl top on my Miata and it works great.
It is often found at boat shops and it is also available on line from many places.
Just be sure the name of the stuff you buy is spelled exactly the way I wrote it at the start of this post.
I have heard there are some copycats around with shoddy stuff for sale.
« Last Edit: October 10, 2017, 02:37:04 am by Arizoni »
sjbiat
Reply #2 on: October 11, 2017, 07:22:28 pm
Thanks so much.  I ordered in on Amazon.
stephan
formerly
97 Motoguzzi
94/02 Ural
85 BMW R80
60 Pugeot
