Author Topic: Royal Enfiled engine builders East coast?  (Read 4267 times)
CaptDan
on: August 28, 2016, 03:37:21 am
Looking for an experienced Royal Enfield engine builder. I am in Tennessee. I want a performance engine. I want someone that knows what they are doing! lol
Reply #1 on: August 28, 2016, 02:10:41 pm
I am in east Tenneessee.
Some people might say that I  know what I am doing.  LOL.
Check my tag line under my avatar on your left. <--
 8)
What engine model are you looking at rebuilding,  and what are your performance goals for it?
« Last Edit: August 28, 2016, 02:20:24 pm by ace.cafe »
Home of the Fireball 535 !
mevocgt
Reply #2 on: August 29, 2016, 01:33:10 am
Ace is the guy.  I have been happy with what he's done with mine...
CaptDan
Reply #3 on: August 29, 2016, 02:53:20 am
That's awesome. Only 1.5 hours from me. Planning on starting a bullet project soon. Will be in touch soon.
Thank you
  • "What's He Building In There"?
Reply #4 on: September 01, 2016, 12:24:14 pm
Thank you
            ACE is the plACE :) Absolutely most definitely without a doubt  ;) 5-stars across the board.
             I can only wish I was that far away from him.
'08 Black AVL Classic.ACEhead 9.8:1/manifold/canister. TM32/Open short bottle/hot tube removed. Pertronix Coil. Fed mandates removed. Gr.TCI. Bobber seat. Battery in right side case. Decomp&all doodads removed. '30s Lucas taillight/7" visored headlight. Much blackout & wire/electrical upgrades
Blod
Reply #5 on: September 05, 2016, 01:29:07 am
Ace
Do you do anything with 350's or is it just 500's ?
Reply #6 on: September 05, 2016, 05:37:15 pm
Ace
All our experience is with the 500/535/612 platform.
We don't have many 350 Bullets here in the States. We could do 350 heads, but we can't bore/hone that small of a bore size in the barrel.
The bottom ends are about the same. We could do them.
In the UK, we recommend the Bullet Whisperer at Performance Classics in Wales.
Blod
Reply #7 on: September 05, 2016, 08:49:35 pm
Will the 500 top end fit on a 350 crankcase OK ?   I don't want to mess with the engine I have, but I was thinking about the possibility of getting another engine with more power to stick in.
 I'm in Canada :)
[/quote]
Reply #8 on: September 05, 2016, 09:41:38 pm
 I'm in Canada :)
It requires machining of the engine case to accept the larger size cylinder barrel,  and moving the stud holes out to the 500 stud pattern.
We have done it, but it is cheaper and easier to just get a  used 500 engine to use as a basis for mods.
Blod
Reply #9 on: September 05, 2016, 11:47:30 pm
I had a feeling it would not be as simple as I was hoping it would be.   I will just have to keep an eye out for an old 500 then. Thanks
Hondo
Reply #10 on: November 28, 2016, 04:49:23 pm
CaptDan, what part of TN? I'm in North Middle TN 45 mins from Nashville. If you are close you can ride "Old Sarge" and see what you think. The ACE team of Tom and Chumma can give you all you need. I'm running a clubman head done by Tom with valves I provided, Chumma did the lower with a ACE 535 coated piston, allow jug, and the Ace bronze bushing instead of the Alpha bearing. Ace magnum cams, Tm32 Flatside with ACE matched intake, and airbox. The bike is simply amazing, far exceeds anything I had in mind!
jez
Reply #11 on: January 11, 2020, 06:15:40 pm
Nicked from Hitchcocks forum. Sadly Tollgate are long gone. The piston is originally for a BSA B44
""On the capacity-hiked 350 front, the Tollgate Classics 441cc conversion is also still an option, the cylinder is re-linered for a 79mm piston, though this also needs a bit of work on the crankcases, as the larger cylinder liner needs to have the crankcase mouth bored out for it to fit."
« Last Edit: January 11, 2020, 06:26:32 pm by jez »
Adrian II
Reply #12 on: January 11, 2020, 07:02:44 pm
John Hutchings (Tollgate Classics) was still working on Bullets when I went to see him back in May, though his old web site might no longer be available, and he lost his partner who used to take care of his computer stuff a while ago.
A.
