Author Topic: What did you do to your RE Continental GT today?  (Read 165978 times)
Otto_Ing
Reply #45 on: February 18, 2016, 05:15:28 pm
I was told that less weight ment more power.  At 7 lbs per poney, I figure that is about a 10 horse gain....????
Ya and the Body Mass Index will improve substantially too rather fast, couple of miles will be enough .... ;D
mevocgt
Reply #46 on: February 18, 2016, 05:19:16 pm
Well, I need to loose some weight anyway....
gashousegorilla
Reply #47 on: February 18, 2016, 11:43:58 pm
Her R.L. Burnside cover on the cigar box is excellent.
   Yes definitely.   And even better as redhead.   Pity,  she just played here last weekend... missed it. :-\
Otto_Ing
Reply #48 on: February 20, 2016, 10:00:00 am
Back to topic...
Sprayed "MEGA GULP" with a plastic filler.
Did a test assembly on the bike.
...the space under the side panel is perfectly filled now.  ;D
« Last Edit: February 20, 2016, 10:11:51 am by oTTo »
KD5ITM
Reply #49 on: February 21, 2016, 12:40:08 am
Real musicians play drums 8)
2014 Continental GT - red
1979 Hurst/Olds W-30 - whit and gold
1964 Volvo PV544 - desert sand
1961 Willys Jeep Utility Wagon - saturn yellow
2014 Trek Madone 5.9
2013 Specialized Carve Pro
Reply #50 on: February 21, 2016, 12:06:50 pm
Mm-hmm...
mevocgt
Reply #51 on: February 21, 2016, 07:52:00 pm
Nice work Otto!  I want one and your handlebars too! ;)
Otto_Ing
Reply #52 on: February 21, 2016, 07:58:35 pm
Thanks MeVo, I have one spare coming in, if needed. I think this one will be good. Good that FJ has been pushy on this subject otherwise I would have probably lived with the radius only. And it has Toms input  ... so it is a child of this forum..
My handle bars will unfortunately always be unaffordable, too low volumes to do a cast... and RE may not want to buy them from me... ;D
Found nice funnels too...they should be an exact match for the hole in the airbox. Hope they come soon.
« Last Edit: March 13, 2016, 10:19:52 pm by oTTo »
Otto_Ing
Reply #53 on: February 23, 2016, 06:22:09 pm
Damn funnels are about 0.5 mm too big, have to remove the airbox out again and make a bigger hole in it.  :'(
Starting to like the airbox layout though,  this will be pretty cool i think.  :D
« Last Edit: February 23, 2016, 07:08:04 pm by oTTo »
Otto_Ing
Reply #54 on: February 23, 2016, 09:02:57 pm
Victory! Sucker went in.
« Last Edit: February 28, 2016, 06:34:17 pm by oTTo »
trimleyman
  • 1953 or 2011.
Reply #55 on: February 23, 2016, 10:27:22 pm
beautiful sunny day here in the SF Bay area and another day that my GT remains in the shop. Hopefully , soon , it will be home and working as it should. Still waiting on the sprag-clutch.
Now 2011 Royal Enfield G5 and just added 2014 Continental GT and latest 2015 Ducati 803 Scrambler Urban Enduro
Then:-
1978 Ducati 900 GTES
1969 Ducati 350 Desmo Racer
1972 Mototrans Ducati 250 24 Horas
1965 Triumph Tiger Cub 200
1967 BSA Bantum
Otto_Ing
Reply #56 on: February 24, 2016, 06:09:35 pm
Test assembled my "environmental friendly" devise  on the slaughtered Motad.   :D
« Last Edit: February 24, 2016, 06:12:07 pm by oTTo »
Otto_Ing
Reply #57 on: February 28, 2016, 04:57:40 pm
finalised the work on the airbox.
« Last Edit: February 28, 2016, 06:51:22 pm by oTTo »
Aus.GT
Reply #58 on: February 29, 2016, 06:49:40 am
Hey oTTo  looks like you opened up the throttle body entry?
1988 Gilera Saturno 500
2014 Continental GT
1985 Ducati Mille S2
Otto_Ing
Reply #59 on: February 29, 2016, 07:52:04 am
I made the hole in the airbox little bigger and pushed a bellmouth in which is same ID as the hole before. It is slightly longer and has a nice entry. Additionally it smoothens the transit to the rubber connector which goes to the throttle body.
Other than that there is no Airfilter infront of it as that will sit now in the MEGA GULP.
« Last Edit: February 29, 2016, 08:12:11 am by oTTo »
