Author Topic: Broken Spokes  (Read 10682 times)
Aus.GT
on: November 19, 2015, 07:32:48 pm
How many people have had a broken spoke on the GT?
I've just had 1 broken on the rear wheel fixed by my local dealer.
they said they have had 1 other in the 40 odd bikes they've sold.
1988 Gilera Saturno 500
2014 Continental GT
1985 Ducati Mille S2
KD5ITM
Reply #1 on: November 19, 2015, 08:48:36 pm
Never had a broken spoke but had to loose spokes in the back and 3 in the front when I brought it home from the dealer. Something I was disappointed that didn't get caught when they did the PDI.
2014 Continental GT - red
1979 Hurst/Olds W-30 - whit and gold
1964 Volvo PV544 - desert sand
1961 Willys Jeep Utility Wagon - saturn yellow
2014 Trek Madone 5.9
2013 Specialized Carve Pro
cafegtgirl
Reply #2 on: November 20, 2015, 03:42:50 am
Getting ready to do a repair for broken spoke. I broken on the rear.
2016 Triumph Street Triple RX
2014 Continental GT
2004 Buell Firebolt XB12R
1998 Buell Thunderbolt S2
1997 Buell Lightning S1
1994 Honda VFR 750
1991 Honda CBR1000
1988 Honda CBR1000 Huricane
1985 Honda VT1100 Shadow (temporary brain freeze)
1985 Honda Helix
1983 Honda VF750F Interceptor #96 made
Reply #3 on: November 20, 2015, 05:53:54 am
 Let me guess, they broke at the hub end din't they ?
 A spoke breaking in normal operation under normal conditions is an indicator of insufficient tensioning.  Imo best to get them checked by an experienced mechanic or a wheel builder.
« Last Edit: November 20, 2015, 06:01:12 am by Ice »
Otto_Ing
Reply #4 on: November 20, 2015, 07:10:07 am
They always break at the hub. I've been building wheels for my cycles and it is not as difficult as it sounds. Appx. equal tension on the spokes is important for equal load distribution, if you have good ears you can play them like a guitar and make sure they sound around the same. Did this check on my GT too and i suspect my dealer has done good work before selling me the GT as all screws were tightend to the correct Torque and all spokes had the same frequency. No issues so far....
iRideRoyalnVA
  • Sole Proprietor of Bremo Synthetic Solutions
  • I sell AMSOIL!
Reply #5 on: November 20, 2015, 08:21:57 am
I've got a broken spoke on my rear wheel, was warrantied with a new one!
2014 Continental GT
Michael C Tolliver
Independent AMSOIL Dealer
Bremo Bluff, Virginia
www.lubedealer.com/bremosyntheticsolutions
Ride Hard! Run Cool!
Aus.GT
Reply #6 on: November 20, 2015, 07:24:24 pm
Let me guess, they broke at the hub end didn't they ?
They always break at the hub. I've been building wheels for my cycles and it is not as difficult as it sounds. Approx. equal tension on the spokes is important for equal load distribution, if you have good ears you can play them like a guitar and make sure they sound around the same. Did this check on my GT too and i suspect my dealer has done good work before selling me the GT as all screws were tightened to the correct Torque and all spokes had the same frequency. No issues so far....
Thanks, Yes was broken at the hub end of the spoke.
I wasn't sure why they break as I have never had experience with spoked wheels. I now know what to look for.
Mine was on the rear as well. LH side outter was the spoke that broke.
2014 Continental GT
Otto_Ing
Reply #7 on: November 20, 2015, 08:02:48 pm
The reason the classic spokes break at the hub is because they are bend there 90 degrees. Modern bicycles often have reduced amount of straight spokes, and sometimes the nipple sits at the hub. The advantage of the classic spokes with the 90 degree bend is however that it is very easy to replace them without removing the wheel from the bike and the tire can remain on the wheel as well.
« Last Edit: November 20, 2015, 08:32:00 pm by Otto »
Reply #8 on: November 20, 2015, 08:25:54 pm
+1 to what Otto said. And the reasons they break there are looseness and un even tensions.  The only times I have seen them strip out or snap at the nipple end was due to corrosion or branches through the wheel spokes.....at night, in the rain...
Otto_Ing
Reply #9 on: November 20, 2015, 08:35:29 pm
.. Ice you have seen something I haven't yet. I have wasted too much of my time in a cubicle probably  ;D
« Last Edit: November 20, 2015, 10:07:02 pm by Otto »
KD5ITM
Reply #10 on: November 21, 2015, 12:11:58 am
The spokes on the GT are what they call a  pull spoke. Where the smoke comes out of the hub and then like a J is typically the weakest point of the spoke. Much like on a bicycle wheel. Higher end bicycle wheels they will have what they call a straight pull spoke. Which comes out of the hub straight and doesn't bend which are a much stronger spoke.
Reply #11 on: November 21, 2015, 06:40:14 pm
 If I would have spent some time in cubicles when younger I might have been able to afford  bikes in better condition !
Aus.GT
Reply #12 on: June 24, 2016, 10:06:57 pm
Ok, As you can see I posted about a broken spoke last November, Well it's happened again about 3 weeks ago. This time I rang my local wheel rebuilder and asked about spoked wheels. He told me the obvious reasons for spokes breaking but also asked if the spokes had a triangle symbol on the head of the spokes. I looked and told him yes, He said that they were Delta spokes made in India and are of variable quality.
So on that basis I had him respoked the rear wheel with some good quality American spokes.
I could have had the spoke replaced under warranty again but figured the same thing would happen again in 6 months and then I have to replace them anyway.
2014 Continental GT
gizzo
  • Live slow, die whenever
Reply #13 on: June 25, 2016, 12:43:29 am
Good to know, aus. I've just had 2 spokes replaced at new tyre time and the wheel tried as well. They broke a while back, I cable tied them to the next one til I got around to having it fixed. Maybe a respoke next time.
simon from south Australia
Continental GT
Pantah
Monster
DR250
DRZ400SM
OnceEveryLampPost
Reply #14 on: April 07, 2019, 08:19:56 pm
Interested to discover that others have had the broken spoke problem , not just me.  My 2017 GT - original rear wheel would break spokes (each one at the bend , both sides - all trailing).  RE replaced the wheel under warranty after the ninth breakage but the new wheel is even worse - 6 broken spokes in 2k miles.  I have been replacing spokes as they go with steel ones (not stainless) and chamfering their respective holes in the hub at the spoke bend.  None of the replacements have broken.
I have since rebuilt the old hub myself with new steel spokes and chamfered holes and fitted it on the bike today.  We shall see how that goes - I'll eat humble pie if they break.
Observations:
1. The original wheels are laced symmetrically with trailing spokes outside (taking drive tension) - but the hub holes are only chamfered on the 'head' side, NOT at the bend (where they should be) so any benefits of this method of lacing (the wrap)  will be lost - discuss.  Some doubts as to the evenness of spoke tension as delivered also.
2. The sharp hole edges are a stress raiser at the spoke bend.
3. The spokes (triangle logo) may be of a low grade of stainless steel which is too brittle for this application.
4.  The new 650 twin has straight pull (almost) spokes in the rear wheel.  ???
I'd be interested in anyone else's recent experiences, observations of criticisms on this matter.  I've only ever had one broken rear spoke (Suzuki GT500) in 49 years on many bikes (British/German/East German/Czech/Japanese from AJS through BMW to Velocette) some of nearly twice the power.
Richard230
Reply #15 on: April 07, 2019, 10:33:58 pm
A few month ago I found a broken spoke in the rear wheel of my 2005 Triumph Bonneville.  While the price of the replacement spoke wasn't bad at around $8, I did have to dismount the rear tire and remove three other spokes to get that one installed and then reinstall the other spokes.  I didn't worry too much about tensioning. I just tightened the spoke nipples using the feel-good method, while tapping each spoke to make sure that they sounded about the same.  ???  That was the first time I ever had a spoke break during 57 years of owning 45 motorcycles.
2011 Royal Enfield B5 500, 2018 16.6 kWh Zero S, 2016 BMW R1200RS, 2009 BMW F650GS, 2005 Triumph Bonneville T-100, 2002 Yamaha FZ1
Jako
Reply #16 on: April 08, 2019, 01:00:17 am
Recently found 2 broken spokes on rear wheel of my brothers GT with only 4000 km ( 2500 miles) didn't bother with warranty he's getting rims and hubs painted black and new quality spokes fitted now by a wheel builder .
B5 2013 ,Honda CT110 2011, Honda C90 cub,  C5 (wife's bike) ,Interceptor 2019 bakers express
Aus.GT
Reply #17 on: April 08, 2019, 08:40:50 am
I have not had a spoke break again after having the rear wheel re-laced with quality spokes.
2014 Continental GT
Morgan60
  • NW USA
Reply #18 on: April 20, 2019, 08:57:48 am
I had a bunch of loose spokes in the front wheel then three in the back with only 600 miles on the clock. All taken care of under warranty.
2008 Bullet Electra Gray
2010 Bullet G5 Deluxe Black
2017 535 GT Continental Red
2018 Himalayan White
2018 Pegasus Green
2019 650 Continental GT Ice Queen or white
2020 Trials 500 Green and Chrome
hpwaco
Reply #19 on: April 21, 2019, 05:55:07 pm
Checked spokes on my 14 GT at 1st oil change.  Several that went "thunk vs ting" were already tightened to the limit.  So far none have broken.   Thought about the old trick of safety wiring crossings, but . . . .    My way back when, my '71 Ducati 450RT (another one of those I should have kept) was really bad about breaking rear spokes until I found a shop in the LA area that specialized in wire wheels and had it rebuilt.
Rusted535
Reply #20 on: April 25, 2019, 11:46:39 pm
No broken ones. But when I brought my CGT home it had a small wiggle in the front. I checked and it had a 4mm lateral run-out! Some spokes were loose some too tight. Really disappointed in my dealer since before I could take delivery they did a full inspection on it.
Anyway, I trued it up myself and now have less than 1mm run-out. SMOOTH.....
gizzo
Reply #21 on: August 31, 2019, 06:35:38 am
Found 2 more broken spokes in the back wheel while washing the GT just now. It's at about 36,000 km and 4 broken spokes from memory.
Continental GT
Pantah
Monster
DR250
DRZ400SM
kelsoo
Reply #22 on: October 15, 2019, 09:15:36 pm
One broken here also. Rear wheel, 3500 miles. On closer inspection some spokes seem neat in the hub holes while others clearly are not.  I'll take a better look when the weather improves.
2018 Continental GT
2006 Ducati Multistrada 1000s DS
1998 Aprilia Pegaso 650
1985 Kawasaki GPZ1000RX
early US import Kawasaki z550LTD (Bobber)
jez
Reply #23 on: January 11, 2020, 05:53:16 pm
  A  broken spoke on any of my bikes past or present is a rarity. I recently rode ten miles with a flat tyre on my old 600cc sidevalve. I put a new tube in and didn't have to even tension the spokes. I've got British Italian and Japanese bikes with all sorts of spoke lacings. As has been said the reason the spokes keep breaking is appalling Indian quality control. No other factor is relevant.
« Last Edit: January 12, 2020, 08:44:25 pm by jez »
