Author Topic: Where to find a Pedestrian Slicer/ Front plate  (Read 4295 times)
TheThrowbackKid
on: August 29, 2013, 02:10:29 am
Sorry, first post & I've tried to find this answer everywhere, but I need to know if there are some specifically made for REs or not. & Where on earth ya buy 'em! I've looked everywhere.
I just put a downpayment on a 2012 C5 in maroon, looking to customize it a bit with tan seats, tan leather saddles, and a ped slicer, but the latter seems to be the most difficult to find!
rvcycleguy
Reply #1 on: August 29, 2013, 02:20:26 am
I recently purchased one on the Nfield gear site.  I ordered mine in basic black without the lettering.  I wanted to custom my own text and I used mailbox letters.  The slicer stands braced 1/8 inch or so above the fender on 3 threaded brass bolts.  The trick is lining them all up in a straight line and allowing for the curve of the fender.  If you space them out to the pre-drilled holes in the slicer, the curve of the fender throws it off slightly.
Reply #2 on: August 29, 2013, 02:31:58 am
Hitchcocks has them too, as do a number of the Indian sites.
However - I don't think you can do better than the one b.sheets got!  Pricey, but just look at it!
http://www.enfieldmotorcycles.com/forum/index.php/topic,16136.0.html
TheThrowbackKid
Reply #3 on: August 29, 2013, 03:46:04 am
Perfect! I hadn't been able to find em on the Nfield site. Nice. & The install info helps! Can't wait to get my hands on her!
Reply #4 on: August 29, 2013, 05:28:44 am
Nfieldgear lists them
http://nfieldgear.com/enfield-store/aftermarket-parts-accessories/graphics/deluxe-front-number-plate.html
With Nfieldgear, it's best to call them at 1-800-358-0938 to make sure they have some available.
They have a habit of having a lot of things on "back order".
squire
Reply #5 on: September 11, 2013, 10:55:56 pm
I ordered the same one b.sheets has, it is pricey but it's the best looking one I could find....well, the only one I could find in Canada, and you get to pick your letters. $90 CAN including shipping from the UK and fittings.
Reply #6 on: September 12, 2013, 01:25:12 am
Like I said, pricey, but just look at it!!!  8)
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Reply #7 on: October 04, 2013, 09:34:57 pm
I have a fancy one of the cast aluminum affairs that have sculpted & polished aluminum frame around the plate, where the numbers go. I haven't put it on the bike, but had an urge to paint the eye on each side that you see on boats from India.
Best Wishes, Craig McClure
D the D
Reply #8 on: October 05, 2013, 04:38:07 am
LOL.  That's kind of cool in a tacky way.  ;D
1975 XLCH
Reply #9 on: October 05, 2013, 12:03:53 pm
And no worse than my B5 tank badge with the reflective red tape stripes...  ;)
  • "What's He Building In There"?
Reply #10 on: October 08, 2013, 02:00:42 am
      I'll just ditto what others have said: Frampton's is the shit. They are probably the best you can get anywhere. From anybody.
       Unless you're into brass.
'08 Black AVL Classic.ACEhead 9.8:1/manifold/canister. TM32/Open short bottle/hot tube removed. Pertronix Coil. Fed mandates removed. Gr.TCI. Bobber seat. Battery in right side case. Decomp&all doodads removed. '30s Lucas taillight/7" visored headlight. Much blackout & wire/electrical upgrades
