RE WD France 2009
August 31, 2015, 07:17:03 pm
Author Topic: 7" Lucas Headlight Conversion?  (Read 2689 times)
aikischmid
« on: September 16, 2011, 03:27:39 pm »
Ok, so I looked through the parts/accessories and installation/usage threads and couldn't find an answer... so here I am!
Just got the 7" Lucas Headlight Conversion Kit in the mail today. I guess I was hoping for some kind of instructions with it. SinghG5 has a youtube video of taking off the old bulb, but I guess I need some instructions about putting the new 7" one in there. Anybody have any experience with this?
Thanks!
2011 Royal Enfield G5 Classic, British Racing Green
aikischmid
Re: 7" Lucas Headlight Conversion?
« Reply #1 on: September 16, 2011, 04:23:09 pm »
Ok, so I just don't know what to do with the red, green, and white wires sticking out of my new bulb. I'll keep looking in the meantime...
olhogrider
  • Black C5
  • 2012 C5
« Reply #2 on: September 16, 2011, 05:58:13 pm »
I didn't get the Lucas bulb since I had other 7 inchers laying around. I just got the rings. I got a real smart ass answer from CMW when I asked how it was supposed to mount. There was no adjustment mechanism and no instructions. How was I supposed to know you toss the adjusters? Anyway, your old bulb should have wires plugged into the back. Just connect the new one the same way, unless Lucas uses Whitworth plugs. ;)
aikischmid
« Reply #3 on: September 17, 2011, 10:44:04 am »
Okay, so here's a picture. I think I just need to figure out how to attach the green/white/red cables from my new light into that white plastic piece. But that means removing the old wires sticking out of the white plastic piece. Do they just yank out? Do I need to get a small tool to push them out from the other side, where the little copper pieces are showing? And then do I replace the little copper pieces onto the new green/white/red wires to reattach them into the white plastic piece?
drbvac
  • Low as it can go
« Reply #4 on: September 17, 2011, 10:50:25 am »
Same colors same wires - I may suggest you use quick splice connectors rather than cutting off the plug in case you switch to another bulb - I have 3 separate bulb retainers including the stock one and rather than cutting anything I used a 7" Sylvania halogen bulb and just put the whole thing into the ring from the minda set. Plug and play as I was having a hell of a time finding the small halogen bulb to use in the other set up.
Dr B
« Reply #5 on: September 17, 2011, 11:56:21 am »
I would use the flat blade connectors on the wires on the lamp and the female version on the headlight assy side. That way you will have almost universal connections for other lamps, particularly H4s. Just get rid of the original connector.
Unfortunately there are no adjustments available on the 7" lamp assemblies which s why they aren't DOT approved. Or, how does the US get stuck with the lousy lights.
olhogrider
  • Black C5
  • 2012 C5
« Reply #6 on: September 17, 2011, 12:16:37 pm »
Like I said in my other post (your other thread), just crimp some connectors (male) onto the bulb's wires and plug them into the female connectors. No need to mess with the bulb or the plastic plug. You are overthinking it, something I am rarely accused of.
« Reply #7 on: September 17, 2011, 08:39:13 pm »
aikischmid
The headlight wires on your UCE are as follows:
Amber = ground
Blue = High beam
Green = Low beam
These show up nicely in bare's picture that he posted above.
The real problem now is to figure out which wire is what the red, green and white wires on your headlight are.  If I had to guess, the white would be ground but this needs to be verified.
The best way to do this is with a volt/ohm meter. (Having one of these is a good idea anyway what with all of the little gremlins that exist in an Enfields wiring harness).
I found a real cheap one at Harbor Freight.   I think it cost about $3.00.
I also bought a really good one at Sears for about $20.
If you have one, set it to read OHMs and touch its probes together.  The meter should read 0.000 (zero).  Be sure to check this to make sure the meter is working.
Now, touch one of the probes to the white wire and the other to the red wire.  If there is NO reading you will know that NEITHER of these wires are the common GROUND wire.
If you get a reading write the number down.  You also now know that ONE of the wires is the ground wire.
Now, touch the probes to the white and the green wire.
If you get a reading, write the number down.  You now also know that the white wire is common to both the high and low beam because it was connected to both of the other wires.  This reaffirms that the white wire is the ground wire.
If you get a reading with the white/green combination but you did NOT get a reading with the white/red combination that means the Green wire is the common GROUND wire and you must repeat the first test using the Red/ Green wires and write down the number.
After you have the numbers you can compare them.  They should be quite different.
The number (of ohms resistance) that is smaller is the HIGH beam.
The number that is larger is the LOW beam.
For example, let's say the white wire was the common Ground wire because it worked with both of the other wires to give a resistance reading.
Lets say the Green/White reading was 4.36 and the Red/White reading was 2.22.
The larger Green/White is the LOW beam and the smaller Red/White is the HIGH beam.
With this knowledge added to the harness wire colors the White wire would connect to the harness Amber wire.  The Green wire would connect to the harness Green wire and the Red wire would connect to the harness Blue wire.
This sorting out which wire is what can be done without an OHM/VOLT meter by using two wires connected to your bikes battery for power and then connecting them to the wire combination's I mentioned above but  you will visually have to try to figure out which combination gives the brighter light to know which wiring combinations are the High and Low beam.
Have fun. :)
aikischmid
« Reply #8 on: September 17, 2011, 08:59:06 pm »
Awesome - thanks for all the help! So electrically speaking, the new 7" Lucas bulb is all wired up and ready to go. The problem I'm experiencing now is anchoring it to the housing. My conversion kit came with six bronze clip-things. I'm assuming I need to use these clips to somehow anchor the headlight to the circular frame, so the headlight doesn't just sag in the housing. Does this make sense? Anyone know what I'm talking about?
« Reply #9 on: September 17, 2011, 09:13:56 pm »
The clips hold the headlight into the rim.
I haven't installed any of them but from my reading I see that they can be a real challenge to install.  It cannot be done without using some needle nose pliers.  Also, there is a chance of braking the light.
Hopefully someone who has done this will add to this topic and maybe have some good pictures of just how those clips fit to the housing and against the flange on the bulb.
They will only work if they are installed right.  Installed wrong and they don't product the force needed to hold the bulb.
jartist
« Reply #10 on: September 17, 2011, 09:33:08 pm »
Wear safety glasses. You'll soon see why.
« Reply #11 on: September 17, 2011, 10:22:48 pm »
I call those wire clip things "dammits"
One slip and TA-Winnngggggg, they fly off to wherever they go,, never to found.
 ( maybe to another dimension ? )
Dammit !!
REA #136
singhg5
« Reply #12 on: September 17, 2011, 10:52:47 pm »
Like Arizoni, if I were to guess I would think that the white wire on your Lucas may be negative (ground) - subject to verification.
However, when I looked at your picture carefully the red and white wires go inside towards the two filaments of the bulb (high and low beam filaments) but green wire stays outside as if it makes contact with the surface of round metal base of bulb.  So it seems to me that green wire should be negative (ground) - though why would anyone use green wire for ground is hard to explain, may be some British wiring color coding system leftover. Ofcourse you should test it be connecting to battery and verifying if my reasoning is correct.
After I had posted the above, I remembered that for the Rear light on my G5 the ground wire is Green  :). I had used that when I installed LEDs as additional rear tail / brake lights for G5.
In your picture, there is a connecting wire (with 3 turquoise female and 2 black connectors) next to bulb. I think that is used in pre-assembled 7" light where these 2 black connectors are used. Perhaps you do not need it.
I also like Bare's idea to get 5/16 inch male blade connectors and attach them to red,white and green wires of your Lucas light. These male connectors will fit into the female turquoise OEM connectors that are in the harness (second photo) currently attached to your 5-3/4" lightbulb. Connect negative of Lucas light to negative of harness (amber), low beam wire of Lucas to Green wire of harness, high beam of Lucas to Blue wire of harness.
PS - Take some pictures of how you attach clips and post them when done in case I need to change my G5 to 7" headlight !
« Last Edit: September 19, 2011, 12:20:55 pm by singhg5 »
1970's Jawa /  Yezdi
2006 Honda Nighthawk
2009 Royal Enfield Black G5
« Reply #13 on: September 18, 2011, 12:17:03 am »
Singhg5
You may be right about the green wire being a ground wire.  Only some testing will tell for sure.
Green, by the way is the common color for a ground wire in American housing wiring.  Any lighting fixture, fan or whatever will have a green ground wire on it that is intended to be attached to the green or uninsulated ( bare) ground wire in a houses wiring circuits.
As for the connectors, yes, by all means 5/16" male connectors should be installed on the Lucas lights wires.
Not only will they make installation easy but if the wires need switching from one supply wire to another they will allow easy removal and re-installation.
GlennF
« Reply #14 on: September 18, 2011, 01:42:09 am »
Do you mean clips like this?
Your headlight will have a glass flat rim going right around the outside at the front. The small U or C shaped bend in the centre sits on the headlight itself flat against the rear of that glass outer rim with the "open end" of the U/C shape pointing outwards at 90 degrees to the headlight aim. The two "legs" clip under the metal chrome surround.
« Last Edit: September 18, 2011, 01:45:36 am by GlennF »
