I was keen to upgrade the indicator tell tale, I felt the poor visibility was a safety hazard and reading a few posts it seems other have had a few issues too. Checking things out it seems that inserting an LED bulb is simple, if a little fiddle removing the housing from the base of the speedo. Full left hand lock and easing with a screwdriver helped a lot. The LED worked fine - but only with one side flashing.
The tell tale is fed by two wires, the power feeds for either the left or right hand flashers. The bulb is earthed via the dead feed. However LEDs are polarity conscious and therefore will only work in one direction. I gather that AC, rather than DC, LEDs are made that would have solved the problem but I couldn't find any. Plan B is a diode kit, £9 from a well known auction site. In essence both feeds go into one wire via diodes, one way valves as it were, preventing power flowing back. These feed into one of the wires to the tell tale, the other tell tale wire runs to earth. If the bulb still doesn't work then turn it round to adjust the polarity. Mine also needed a little fiddle as well to ensure a good contact.
I fitted mine in less than 30 minutes. Taking the headlamp off made life easier in terms of accessing the tell tale wires. I cut these, fitted the bullet connectors and patched in the harness. The earth ran to the speedometer bracket. The bulb holder was inserted back in the speedo and for good measure i also replaced the neutral light. Job done in less than 30 minutes at a cost of around £12.50 for bulbs and wiring kit.
I attach a few images to show the basics. Apologies if I am walking on well trodden ground here, but posted in the spirit that it may help somebody else.
