I must admit I never fully considered the cooling aspect of the big bore. It’s one of the annoying things I find on the stock bike is that it lacks any temp read out / feedback. After washing my bike I usually leave it running to help dry off any left over moisture and it’s always in the back of my mind about cooking it. I am sure S&S tested this but I would be tempted to pick up a pico temp prob and attach it to the back of the cylinder block for a day or so just to see if there has been a noticeable jump
I bought a pet dryer (powerful one) that looks about the same as a purpose made bike dryer but costs less. Have found it blows water out of places you wouldn't believe it could collect, it helps no-end with cleaning.
I saw this and got all excited. I thought it was it was going to be an 865 cooling fan/ diy turbo kit.I feel feel let down.
which dryer unit did you buy? Got a link? I tried using the air blower straight off my shop's air compressor, but a lot of moisture comes out which kind of defeats the purpose...
(my air compressor has a water drain at the bottom of the tank)
Mine don't. there's a valve at the bottom to drain all the air out of the tank, but nothing that is specifically for emptying water.
Speaking as a guy with a fair amount of compressor experience, up to 10K psi, and meaning no disrespect, I believe that valve is actually a drain port for removing water and debris. Use it often. I've seen a couple of those small compressors rot their tanks and explode causing serious damage. I worked with a guy that was sitting in the cab of a truck when a 3K unit blew apart due to rust. Chunks blew through the back of the cab and killed him. I'd hate to see a post here about anything like that.
Oh, not taken as disrespect at all. I'm not what most people would call "handy," and that includes air compressors. I've only had the compressor a few months and have used it maybe five times. It's a 35 gallon, 125 PSI unit, so not huge. I opened the valve last night after reading the post here and a tiny bit of moisture came out for about three seconds, all clear, not rusty or anything. Then I just "drained" the tank of air and went back in the house.
Do that every time you use it and you'll never have any problems. Do it like I do, which is when I remember to do it, and you probably won't have any problems either. Big units have an automatic "blow down" on them that vents the tank at predetermined intervals, some of the ship board units I worked on would pump out five gallons of water for every 8 hours they ran.
Thanks for the advice, genuinely. So would doing so lessen the amount of moisture that comes out when using it as just a blower for getting water out of tight places on the bike after a wash?
Yes.Let the tank build up a little pressure to blow the water out. tighten the drain and blow away.
