I fitted the Scottoiler tonight and it was reasonably easy to do. You really have to take off the side covers to reach the vacuum pipe for the EVAP system to fit the T piece. I found it easier to take the pipe off the throttle body and pull it through to the left hand side, it makes it easier to cut the pipe as there is a lot of wiring loom in the way, tie a length of thin string to the pipe before pulling it through as it makes it easy to feed back to the throttle body.
I fitted the reservoir as in the picture below, it is held in by industrial velcro as a trial but if it does not move then I will leave it as it is.
I know it does not look like it but the pipes are under the seat and out of the way.
The mounting for the feed to the sprocket was cobbled together from a Scottoiler supplied stick on bracket and one of their cut down wheel spindle mounts off my other bike.
You will have noticed there is no oil in the pipe as some clown left his bottle of oil in his other bike and I can not get it until tomorrow so a test will have to wait till then.
