Author Topic: Delete electric start  (Read 2668 times)
armando_chavez
on: September 26, 2013, 12:08:01 am
Is it possible to delete the e-start and get a smaller battery that would fit in my fat tail cafe seat.
Reply #1 on: September 26, 2013, 02:17:46 am
Absolutely.
DanB
Reply #2 on: September 26, 2013, 02:26:31 am
A couple of threads down in this forum. Can't miss it
http://www.enfieldmotorcycles.com/forum/index.php/topic,17234.0.html
2006 AVL Electra
Superchuck
Reply #3 on: September 26, 2013, 03:21:41 pm
Here's what I ended up installing a few weeks ago...  My solenoid crapped out a while back, so I just removed that component and the wires connecting it to the starter.  Some people go as far as to remove the sprag from inside the primary case, and sometimes the inner workings of the starter, although I think you need to keep the starter's housing since there isn't a readily available part to close off the gaping hole it would leave in the front of your engine.
Battery I bought... 1000 miles on it and it's working great.  This battery is so small that I imagine anything would work on a kick-only machine:
 http://www.google.com/search?client=safari&rls=en&q=YT4B-BS+AGM&ie=UTF-8&oe=UTF-8
It's basically a tiny dirt bike battery.  Some guys on a triumph forum say it works great for their older kick-only 650's.  This particular model is great because it's only 1.5 inches thick so i can tuck it up under the seat, and the best part, you can find it for $20 including shipping.  Added to that, it's an AGM battery so I can use my battery tender that I already have, and don't need to invest in a high tech charging system.
It's only 2.5 AH but heck, it's twenty bucks.
Good luck, and great lookin bike!
Chuck
Rosetap
  • Credit Card? You got it.
Superchuck
Reply #5 on: September 28, 2013, 05:22:20 pm
Well lookee there!
armando_chavez
Reply #6 on: September 28, 2013, 05:47:43 pm
Hitchcocks has a cap for it no???
ERC
Reply #7 on: September 28, 2013, 11:06:39 pm
Yes. ERC
