Ok so bought a GT535 as a bit of a project and got a few fault codes present. It starts and rides ok, so I'm wondering if some of these are just old codes needing to be cleared. The MIL doesn't stay on at idle only lights up after you get going.
I have:
LONG 1 SHORT 1 Engine oil Temperature (TE) circuit malfunctioning. Tried to google this, not a lot coming up so far.
LONG 4 SHORT 5 O2 Sensor heater circuit malfunctioning.
Exhaust not original, power commander installed, o2 sensor has been removed, I assume this is down to this? Interested to find out where an o2 sensor eliminator might be found. If it's not been done this would hopefully be an easy fix.
LONG 3 SHORT 3 Injector circuit malfunctioning
LONG 4 SHORT 1 Fuel Pump circuit malfunctioning
As the bike starts and runs are these last 2 likely old faults that just need clearing or is that wishful thinking?
The seller informed me he took the bike to a RE mechanic and they told him the fault light was just down to the o2 sensor being removed. Want to find out a bit more before I take that as gospel though
Thank you!
