Move it, you have an incipient failure and you'll be buying another $50 coil soon if you don't.
Paint it gloss black & mount it below the fuel tank on the frame, near the plug. The Bosch is (I believe) epoxy filled so it doesn't care about orientation. Practicality is the driver here, you can't allow vibration to eat into the coil body or spark lead. Short spark leads are good, a couple of wires to the coil are cheap.
