Royal Enfield Motorcycles => Bullet Iron Barrel => Topic started by: arindamcc on February 18, 2013, 06:00:15 am
I want to change my 350 std stock alternator.Which alternator are best for my bike SPARX High output 210 watt three phase alternator or wassell single phase 200 watt alternator.Please give some advice if anyone fitted high output alternator on Bullet 350 std.
I found that my original 6 volt alternator put out fine with a Boyer Powerbox, I did end up running a battery with it as I seemed to get some missing at low rpm with the headlight on(and a dull headlight). At some point I had a coil short in the windings and had to replace the stator, I used stock one off of a more modern Bullet 500 with the separate lighting circuit, I ran connected these in parallel with the charging circuit into the Powerbox and always seemed to have good charging except at the lowest idle, not sure what you are planning on powering....(My bike was originally 6 volt positive ground with a rectifier, I converted to 12 volt negative ground)
