I started sweating the thought of doing an oil change this weekend. I have nightmares of stripping the cases out...
Nothing to fear if you have a small torque wrench and the right sized sockets and screw in the bolts/plugs all the way to snug with your fingers. (If they screw in with finger pressure you know they are not cross threaded).
Torque the main drain plug towards the rear of the engine to 13-15 lb/ft.
Torque all of the small head bolts on the oil pump inlet cover and filter cover to 3 1/2-4 lb/ft.
I don't know what the torque value is for the forward drain on the bottom of the crankcase is but you can safely use the values in the chart attached.
Note: The metric sizes in the chart are the actual thread size. They are not the size of the wrench you use to loosen/tighten the bolt.
Use the lubricated aluminum values.
