Author Topic: What did you do to your RE Continental GT today?  (Read 391299 times)
Otto_Ing
Reply #375 on: September 20, 2016, 04:12:09 pm
I started sweating the thought of doing an oil change this weekend. I have nightmares of stripping the cases out...
If that happens there are helicoils.
longstrokeclassic
Reply #376 on: September 20, 2016, 10:21:17 pm
Suitable location for a Fumoto drain valve?
Never underestimate the value of improved combustion efficiency and reducing parasitic engine and rolling chassis losses.
Reply #377 on: September 20, 2016, 10:54:58 pm
Nothing to fear if you have a small torque wrench and the right sized sockets and screw in the bolts/plugs all the way to snug with your fingers.  (If they screw in with finger pressure you know they are not cross threaded).
Torque the main drain plug towards the rear of the engine to 13-15 lb/ft.
Torque all of the small head bolts on the oil pump inlet cover and filter cover to 3 1/2-4 lb/ft.
I don't know what the torque value is for the forward drain on the bottom of the crankcase is but you can safely use the values in the chart attached.
Note:  The metric sizes in the chart are the actual thread size.  They are not the size of the wrench you use to loosen/tighten the bolt.
 Use the lubricated aluminum values.
L4V
Reply #378 on: September 20, 2016, 11:41:52 pm
That's scary.
 In thew US, we have Buchanon's.
Buchanan's sells worldwide and one of, if not, the most repsected Spoke/Wheel companies.
Mail them a spoke and they'll send you a new/better one.
I've been a customer a few times.  I live in the US (Arizona).
http://www.buchananspokes.com/
OK, so you liked the soap, but never walk out of a public restroom smelling your fingers.
1975 Yamaha DT400 (572 original miles)
1989 Yamaha TDR250
1999 BMW R1100S
2010 Suzuki DRZ400
2012 Ducati Hypermotard 1100 EVO SP
2013 Fiat Abarth
2014 Continental GT (Red)
etc.....
Farmer_John
Reply #379 on: September 21, 2016, 08:59:59 am
And that's the thing. Where in the world do you find a torque wrench that reads down to 3.5-4lbs.
I mean if Harbor Freight doesn't carry them...
"It's not what you know, it's how well you reference what you don't"
"Ain't no hill too high for a mountain climber"
Words to succeed by...
Otto_Ing
Reply #380 on: September 21, 2016, 09:09:41 am
Ebay will have it, here some HQ example:
Wera:
http://www.ebay.com/itm/Wera-7000-A-Torque-Wrench-1-25-Nm-Reversible-Ratchet-1-4-Drive-/161994190204?hash=item25b79b2d7c:g:1XIAAOSwezVW1g~v
HAZET:
http://www.ebay.com/itm/HAZET-DREHMOMENTSCHLUSSEL-5108-2CT-UMSCHALTKNARRE-2-5-25-NM-1-4-KNARRE-RATSCHE-/391450243167?hash=item5b2440b05f:g:uecAAOSw2x1XLKCv
...or you can get a 25$ one from China, which may be good enough for this job. I like good tools though.
« Last Edit: September 21, 2016, 09:12:15 am by oTTo »
Reply #381 on: September 21, 2016, 01:42:02 pm
I use a small one that reads in inch-pounds.
Flex pointer type. Not expensive.
Home of the Fireball 535 !
gizzo
  • purple people
Reply #382 on: September 21, 2016, 04:27:22 pm
I got mine from a bicycle shop.
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
Reply #383 on: September 21, 2016, 10:39:40 pm
Farmer John:  Are you thinking of a 1/2" drive wrench?  If so, you may be right in saying it can't be set that low.
I have a 3/8 drive, ratchet type spring "click" torque wrench.
It's torque settings start at 1/2 lb/ft so setting it at 4 lb/ft is just a matter of twisting and locking the adjustment handle.
Mine is a Snap-On but I would be surprised if the Harbor Freight 3/8 drive click style torque wrench would not have similar settings.
By the way, the Harbor Freight click torque wrenches are supposed to be accurate to ±5% which is actually pretty accurate.
« Last Edit: September 21, 2016, 10:41:56 pm by Arizoni »
Farmer_John
mevocgt
Reply #385 on: September 22, 2016, 03:27:44 am
Sears craftsman......
Farmer_John
Reply #386 on: September 22, 2016, 06:33:56 am
Unless I skipped over it, there isn't one...????
Otto_Ing
Reply #387 on: September 22, 2016, 06:39:59 am
Wallmart or Autozone won't have it?
Guaire
ACE Motors - sales & administration
mevocgt
Reply #389 on: September 22, 2016, 01:44:37 pm
Well, they use to.  I bought mine a couple of years ago, and paid 30 bucks for it.  Good luck on the search though......
