Hello All
I've put a new battery on my 535 GT and bow it won't start. Battery is the correct version, starter motor working well and I have a spark. The issue seems to be with fuel? When turning on the ignition and the engine switch I think there should be the sound of the fuel pump priming? This only seems to happen every 10-15 times I switch the ignition on, in between that I can just hear a click somewhere around the battery/under the saddle??? It won't kick start either, I'm convinced it's fuel flow related? Any help appreciated 🙏
