Author Topic: front suspension tuning  (Read 8497 times)
a10ken
  • barrow in furness uk
on: October 03, 2019, 02:38:54 pm
how do folks, has anyone tried to improve on the std  soft front suspension setup yet, i am going to have a go when i put the interceptor to bed for winter
interceptor 650
xl1200s sport
buell m2
k75
mt500
f650
Oldie but Goldie
Reply #1 on: October 03, 2019, 02:48:41 pm
Fitted TEC adjuster and works fine. A little bit stiffer. Also Hitchcocks sell similar pieces.
No matter the bike you ride
Wind is the same for all...
a10ken
Reply #2 on: October 03, 2019, 02:55:28 pm
yea i looked at them, didn't fancy raising the bars to accommodate the adjuster, also with the stiffer spring rate the fork oil could do with going up a grade as the damping will be affected
interceptor 650
xl1200s sport
buell m2
k75
mt500
f650
Dr Mayhem
Reply #3 on: October 03, 2019, 04:05:19 pm
down the road I'll be looking at a valve kit and some straight wound springs (poor man's anti-dive)  ;D
Guy
19 Conti GT in Dr Mayhem paint 08/24/2019
06 HD Street Bob
04 Buell XB12S Lightning
darmahman
  • I've lived in Colorado for the past 43 years.
Reply #4 on: October 04, 2019, 02:11:49 pm
I did the Hitchcock stiffer springs and preload adj. Works like a charm. Preload adjuster is all the way backed off and it is perfect. Basically it compresses the new springs slightly even when turned back all the way. Very high quality piece.  Plus I changed to 7 1/2 weight oil.
Still tho I don't like the feel above 65. A little bit too wandery for my taste. Going up one size front and rear on tires next. I think the bike is under -tired. Plus Ohlins rear shock is on the way.
By the way, I am 200 lbs.
« Last Edit: October 04, 2019, 02:15:34 pm by darmahman »
Scram 411, Moto Guzzi V85, BMW R100GS, Road King, BMW R1200C , Suzuki DRZ-400E
58webbing
Reply #5 on: October 07, 2019, 03:33:39 pm
Although the handling on my interceptor was OK I did not like the way the front end sagged when sitting on it or the way the gaiters closed right up when braking.
According to the specs the front fork travel is 110mm. When I took my bike off the centre stand and put it on the side stand it used 15mm of travel. When I sat on the bike (I weigh 89kg) it used 50mm of travel so my conclusion is nearly 50% of travel is used before riding over bumps and using the front brake.
As the suspension characteristics suited me I did not want to fit stiffer springs but to increase the ride height and available travel, this I did by fitting some 16mm spacers. (photos attached)
The gaiter pictures show on the stand and me sitting on the bike, the parts are a nylon spacer 14.5mm thick and 35mm dia. and the aluminium spacers are 3mm thick, 35mm dia. and reduced to 33mm for 1.5mm to fit inside the fork spring spacer tube. The assembly picture shows the parts in order prior to fitting.
The front end does not dip so much now when I bounce myself on the bike with both front and rear suspension moving together.
2019 Royal Enfield Interceptor
2019 Honda CB650R
2020 SurRon Light Bee
2018 Royal Enfield Bullet
2022 Royal Enfield Meteor
a10ken
Reply #6 on: October 08, 2019, 02:35:42 pm
hi 58, thats pretty much what i had in mind to right down to the 16mm spacers, however i will be using heavier oil to slow down the rebound action as the springs will be under an initial higher tension.
interceptor 650
xl1200s sport
buell m2
k75
mt500
f650
58webbing
Reply #7 on: October 08, 2019, 04:13:28 pm
Hi Neophyte,
I dont think you will need to change the oil as the std. damping is very good. 16mm spacers will not increase the spring rating by much but will increase the ride height and make available some more travel.
2019 Honda CB650R
a10ken
Reply #8 on: October 09, 2019, 09:49:48 am
i will be looking at the grade and amount of oil as the front end clacks anoyingly
interceptor 650
xl1200s sport
buell m2
k75
mt500
f650
a10ken
Reply #9 on: October 09, 2019, 11:38:09 am
p/s forgot to mention but i am 77kg stood here in my work gear.
interceptor 650
xl1200s sport
buell m2
k75
mt500
f650
Reply #10 on: October 09, 2019, 12:03:09 pm
Sorry, but as I'm not always the sharpest tool in the shed: it looks like all you've effectively done here is make a taller cap, which I can see would raise the right height (as well as increase the wheelbase slightly?) and retain the spring rate (since the compression of the spring hasn't changed)... but I don't see how this arrangement increases the available travel.  What am I missing?
a10ken
Reply #11 on: October 09, 2019, 12:50:19 pm
the fork length stays the same but the spacers reduces the available space inside by compressing the spring slightly therefor increasing pressure on the spring and causing the fork to extend taking up some of the sag raising the ride height slightly
interceptor 650
xl1200s sport
buell m2
k75
mt500
f650
58webbing
Reply #12 on: October 09, 2019, 06:46:29 pm
Today I had a good ride around with the 16mm spacers and found the effort of making and fitting them well worth while. I deliberatly headed for bumps an hollows at speed to see what happened. The gaiters showed the ride height increased, the steering "seemed" more precise on bends, the braking was less dippy and no difference to rebound damping was noticed. So, overall I am very pleased. Also the handlebars were effectively raised too.
With no load to the forks the std spring spacers were flush with the top of the forks which to me seemed unusual compared with lots of other forks I have worked on where the springs always protuded somewhat. I think that spacers up to 20mm thick could easily be added with no ill effect, though more effort would be needed to refit the caps, more than that the springs would have to checked to make sure they dont become coil bound on full compression.
As we all are different weights and have different riding styles and preferences adjusting the forks with just spacers is a simple 1st step.
2019 Honda CB650R
a10ken
Reply #13 on: October 10, 2019, 10:14:52 am
cant argue with that.
interceptor 650
xl1200s sport
buell m2
k75
mt500
f650
58webbing
Reply #14 on: October 10, 2019, 10:34:39 am
With regard to the clacking "from your forks" could it be the backlash in the floating disc. There is not anything in the forks that could cause that noise (apart from something very seriously wrong) however rocking the bike back and forth with the front brake on does cause a "clacking" noise and that is the front disc. This would appear to be normal, at least for the Interceptor.
2019 Honda CB650R
