Hi A10ken,
your comments on the damping got me to thinking, as when I set off on a journey I hear some road bump related rattling which I first thought was something loose however after a few hundred yards it disapeared. So first thing this morning I bounced the forks up and down and sure enough no or very little damping afer a few seconds the damping "became normal". My conclusion is the oil is settling and needs a little pumping to get it to where it is needed. What to do? I dont think a thicker oil would help me as once I am up and away everything is fine. Do I raise the level as this would increase the air pressure in the forks and possibly pop the seals as well as make the forks stiffer. I have come across having to work the suspension on other bikes and is something I can live with.
I look forward with interest on your findings with changing your oil, finding your comments so far have helped me find out more about the Interceptor,s characteristics.
Today I will make and fit some 20mm spacers.
