If the originals are iron, just be aware it's not a foregone conclusion that the old ones will come out willingly!
I even made a puller for the kickstart shaft one using a large rowlbolt screwed into the bushing and a piece of steel tube as a spacer to try to wind it out. Even with a load of heat it refused. I landed up drilling down the centre with a blacksmiths drill then breaking the remaining shell out into the middle with a cold chisel. Then the new bushing contracted so much after fitting that the shaft wouldn't fit and I had to make up a sort of flap wheel with emery cloth in a slotted tube to hone the ID slightly.
Took me almost all day.
