Go to the Hitchcock's "Parts Book Online" section, match & verify what you have there.
https://accessories.hitchcocksmotorcycles.com/Parts-Book-OnlineThe IB was made to 2008 as a 4-speed, drum brake, KS & ES. The "Sixty-Five" had the 5 speed. The 5-speed is fully retrofittable to the IB and is about a $1000 worth of improvement. There is a front disc brake kit, well worth it if you commute daily in traffic. That you actually have a Boyer, that rather says it's the older IB motor. Boyers are great, they have an "extra retard" function for starting, so a lot (if not all) of kickback is avoided. At 500 RPM (idle) they resume the normal curve.
If you have the older IB engine, not the AVL/Electra engine, it'll have a 28mm Mikcarb on it and a bushing bottom end. The bushing bottom end doesn't like lugging or lots of revs, just let it "run freely" under only moderate loading. These cranks last between 5K miles and 80K miles, depending on original fitment, lubrication and the amount of thrashing they get. Replacement requires case splitting. Depending on what you go with, it can run between $600 - $2200 just for parts, so you can see that "mechanical sympathy" and good maintenance are rewarded.
Until you pull the top end you won't know what piston is in there. The OEM cast "Velveeta" pistons can fail catastrophically in at least three ways: Seizure, dropping the skirt and shucking the crown. The OEM con rods don't like high revs either. The "fix" is a forged piston in an alloy barrel. Otherwise, just ride it sedately and be happy. With a forged piston, still don't buzz it. A broken rod will easily destroy the crankcases.
You also need to inspect the Quill seal. It can be either rubber or cork and HAS to be in good condition. I've found two with their guts vulcanized to the Quill bolt, but apparently still sealing "enough". You can try to look thru the Quill bolt hole or just pull the timing cover off. Have a new timing cover gasket handy before you start just in case the old one self destructs. A great time to change the oil filter and check the cam timing too. Don't let the distributor gears slip off their shafts as you can easily lose the engine timing you have that's working now.
The rule of thumb for the old IB motor is "55 all day, 60 for awhile, 80 one time". Unless
you know there's upgraded internal bits, I'd treat that as gospel. Add to that "no lugging, no buzzing" and you're all set.
I'd get the appropriate gaskets from Hitchcock's and when you're ready pop off the top end and see for yourself what's in there. If you see a steel conrod, happy days you might already have the $1800 Hitchcock's roller crank!
In any event, your 5-speed Bullet is a great time machine that allows you to get a real feel for the 1935 riding experience. I enjoy mine tremendously. Pull maintenance, learn their quirks & needs, you'll have a great time chuffing about.
